would it be possible to use a starter solenoid from a car or truck , like I have on my '72 ford, to start my bike. The old solenoid is bad and I just want to start the bike.
Starter solenoid-??????
Yes you can, it works the same way. Problem you might have is the automotive ones are probably larger and might not fit under the side cover. Possibly could be relocated? BTW, the stock unit can be disassembled and repaired, someone has written a good tech tip on this.2H7 (79) owned since '89
Your starter switch is probably shorting. Check continuity on the wires to the switch. They should not have continuity unless the button is pressed.1980 XS850SG - Sold
-H. FordComment
There are 4 connections. Usually 2 large, and 2 small.
1 large - positive battery connection
2 large - line to starter (and the TCI)
3 small - line to switch
4 small - line to switch
There should be no connection between 3 & 4 unless the starter button is pressed. Releasing the starter button (thereby cutting the electicity to the starter) is the only thing that stops the starter from spinning. If the switch is shorted somewhere, and is not disconnecting, that could be what is allowing the starter to spin as soon as the key is powered on.1980 XS850SG - Sold
-H. FordComment
I think I know what's going on.....I did the same thing to mine The blue with white stripe wire grounds out on the bottom metal mounting plate of the solenoid. But the bottom mounting plate cannot be grounded to the frame that's why mine is mounted to a board and the board is mounted to the frame.........it's the only way I could get my Ford solenoid to work. here's a pic
Tulsa, OKComment
Ahh! That's why the stock solenoid is suspended in a rubber "sling"! Good to know!
-H. FordComment
Thanks for the help. I hooked up the solenoid as you have done in the pic and now everything works fine. The difference in my mounting however is that I found some rubber isolators at the local True Value which allow me to mount it to the steel plate I had welded in place and the isolators keep it from grounding.I think I know what's going on.....I did the same thing to mine The blue with white stripe wire grounds out on the bottom metal mounting plate of the solenoid. But the bottom mounting plate cannot be grounded to the frame that's why mine is mounted to a board and the board is mounted to the frame.........it's the only way I could get my Ford solenoid to work. here's a pic
Thanks again,
RobComment
