front brake master cylinder cover leaking
  • sheridanredneck
    • Feb 2010
    • 34
    • Sheridan, Texas
    my front master cylinder cover leaks a lil round the edges, do they make a replacement cover n gasket or can i get a reasonably priced replacement master cylinder for my '81 xs 1100?
    Bike Bandit shows the parts still available on this page:
    Their parts 2,3,4:
    2: CAP,RESERVOIR
    10787-001 Enter 0-99 $39.70
    3: BUSH,DIAPHRAGM
    10791-001 Enter 0-99 $13.98
    4: DIAPHRAGM RESERVOR
    10789-001 Enter 0-99 $17.12
    That being said, you can get a replacement NEW master cylinder from several sources for about $80.00....ie. Partsnmore.com or MikesXS.net !
    Several folks have gotten the new MC's and have been happy with them.
    Just be sure to to get the larger bore ones for dual caliper systems!
    • rpgoerlich
      • Dec 2007
      • 643
      • Katy, Tx
      Hey Shannon, the cap, bushing and diaphragm are still available.
      2 SKU: 1J3-25852-01-00 CAP, RESERVOIR 1 $28.58
      3 SKU: 1J3-25855-01-00 BUSH, DIAPHRAGM 1 $10.07
      4 SKU: 1J3-25854-01-00 DIAPHRAGM RESERVOR 1 $12.33
      If you cant find one locally, online parts stores like:
      http://www.powersedge.com
      I'm sure there are a few more.
      Richard
      • fabricgator
        • Feb 2010
        • 67
        • Treasure Coast, Florida
        Hey Guys,
        What is the seal from the plastic reservoir to the metal casting on the stock front brake master... I did not see it on the IPC from the second post link (illustrated parts catalog). I seem to remember that seeping and I used RTV silicon (only lasts for a season or so).
        Is it an O ring or a square cut seal.... a gasket? I don't think there is one in the standard rebuild kit.
        Are they available? Any good sourcing?
        Thanks, Kurt
        Kurt
        I have a parking problem everywhere I go....
        2001 Mitsubishi Montero
        1987 944 n/a
        1979 Titan
        1979 Yamaha XS 1100 SF
        1984 Suzuki SP 250
        1987 Santana 23
        1944 Aeronca L-3B Grasshopper
        If it fly's, float's or fornicates..... your better off having a lease!
          Cap on my front has same issue....very slight as it is just a bit warped(slight arc across center), will watch for NOS one, as it just has an occassional damp at cap sealing seam. Nice to know the source if it becomes an issue!
          • fabricgator
            • Feb 2010
            • 67
            I recently saw NOS on Ebay for about thirty some odd dollars.... I would have liked to have it, but......
            Kurt
            1987 944 n/a
            1979 Titan
            1984 Suzuki SP 250
            1987 Santana 23
              on my SH models, the reservior mounts to the MC by a round section that fits down into the round metal part of the MC. There is a groove in the plastic reservior where it drops into the MC that takes an o-ring.
              • sheridanredneck
                • Feb 2010
                • 34
                • Sheridan, Texas
                thanks so much guys! every time i need help, ya'll r so willing to help, thank u n keep up this great site!
                • SFerinTEXAS
                  • Jun 2006
                  • 877
                  mikesxs
                  MIKESXS Part #08-7000 $34
                  79SF
                  XJ11
                  78E
                  • fabricgator
                    • Feb 2010
                    • 67
                    Yeah, the o ring..... That's what I need! Any idea where to get one? Size? Part number? If I were to source an o ring on the street, is there any particular type of material that should order that holds up to brake fluid?
                    I don't see that o ring on any of the parts manual's....
                    Kurt
                    1987 944 n/a
                    1979 Titan
                    1984 Suzuki SP 250
                    1987 Santana 23
                      There is no parts listing for that O-ring. Best bet is to take the old one to a hydraulic shop and have them match it up. If you do find one, pls. let us know the size for future reference.
