Has anyone put a 110/90/19 on their XJ1100 ??? How does it fit and handle?
Just ME and my 82 XJ 1100. Mac 4>1-2 1/2" open baffle shotgun, no octy, K&N pod filters, LED tail/brake light & directionals, 750 FD mod, Ear Cannon air horn, modified bars and dash. "Motorcyclists are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what machine he rides as long as he belongs to the clan." Walter Davidson, Dec. 1920 edition of Harley-Davidson Enthusiast Magazine http://s851.photobucket.com/albums/ab78/justme1100/
I'm pretty sure that some XJ owner's have done this, but they don't visit the site as often, as well as there aren't as many XJ owners as XS.
I have put a 110/90-19 on my 81SH, fit just fine, handles fine. Due to a old front end collision, and the dealer putting the wrong replacement fender on it, I had to grind the mounting holes a little wider to allow some tilting of the fender to keep it from rubbing the tire on the front edge at high speed!
The XJ has a built in forkbrace in the front fender, so there might not be as much side room as on my 81. You can measure the width inside the fender at it's narrowest, and then compare that to the tire specs width for the brand you are looking to get to see if the tire is not as wide!
79SF "The Teacher" . . .basket case! History shows again and again,
Hi Mike,
I'd suppose the 10mm width change would make less difference than other changes; like changing a worn tire for a new one or a nasty tire for a nice one.
What might give problems is fender clearance. Although it's not a direct comparison, my son has a 110/90-19 on the front of his XS750 Special and there's mebbe 1/8" clearance between the tire and the fender.
Betcha he wouldn't get 50 yards up a rain-soaked dirt road before the wheel was mud-locked.
