1179 Piston Pin Clip Install - trickto this ?
  • Bullet
    • May 2007
    • 185
    • Alliston | Ontario | Canada
    Gonna try to get my pistons installed this morning .
    Anyone got a trick to get these little wire C clips into pistons ?
    Rings are installed, and I can do one clip before I put the piston on the rods, but the other side is gonna be tricky at best without dropping one of these little clips down the engine case ..
    thanks .
    1980 SG - "Blue Balls"
    Complete Restoration - Finished June 21/2010
    - 1179 kit
    - 80/81 carbs 42.5/115 mains with XS pods
    - Mac 4 into 1 exhaust
    - Venture auto CCT
    - progressive fork springs - no air
    - Mike's progressive rear shocks
    - Galfer S.S. Brake Lines
    - XSDirect - Black Coils
    - 8 mm S.S. Core Plug Wires
    - T.C. fuse box
    - TKat fork brace
    - Geezer regulator
    - Battlax BT45 V-Rated tires
    - 5W40 - Rotella T6 Synth Engine Oil
    - rest of bike is "good old Yamaha"
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    I used a dowel with a slot cut in to help hold it.
    it worked good video of me doing it shows mostly my shoulder but the clips went in without them springing aroung all over the place.
    Good Luck
    Rick
    650SF
    XS1100SG Project bike
      Stuff lots of shop rags around the con rods so there is no way anything can drop into the crankcase.
      • Bullet
        • May 2007
        • 185
        thanks guys, we got them in without any casualties or any clips going awol ..
        You would think some Wiseco would "wise" up and use some circlips on these kits .. oh well ..
        Anyway
        tinman and I used some hi-tech tools here .. lol ..
        3 pieces of wood and a plastic quick grip clamp, worked like a charm ..
        - 1179 kit
        - Venture auto CCT
        - T.C. fuse box
        - TKat fork brace
        - Geezer regulator
