newbe to sx11's..headlight ?
  • brcree
    • Mar 2010
    • 388
    • S.C.
    When you turn the key on should the headlight light up or, after the eng. has started and is running does the headlight light up? This will answere alot of questions here.
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    If everything is stock then when you turn the key on you should get tail light only. Then when you start the bike you should get the headlight. With key on bike not running your headlight will not be on.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
    • brcree
      • Mar 2010
      • 388
      • S.C.
      headlight prob
      Thats what I thought, just needed to be sure....thanks man. Saved me from buying a bunch of unnecessary elect. parts!
      At this time:
      1985 Goldwing Innr.
      2007 vtx 1300
      81 sx 1100 s h
      81 sx 400 special
      • sheridanredneck
        • Feb 2010
        • 34
        • Sheridan, Texas
        so what if after u start it, it still don't come on? but it comes on when it wants & goes off when it wants, even with a new bulb? please help?
          • 8797
          If you have the old glass fuse box still, I'd check there for a flaky connection/fuse first.
          • Brad
            • 136
            • Regina, SK CANADA
            Burnt wire, grounding out, weak wire connection, corroded wire could be other possiabilities. Found mine when I looked in my wiring harness and seen a burnt piece of wire, grounding out against the frame when turning.
            Some make 'em, most just make payments on 'em!
            1978 XS 1100E
            Vance & Hines Slip on Straight Shot Exhaust
            K & N Air filter
            Home built forward controls
            Vulcan Mustang seat
            A little chopped
            http://s812.photobucket.com/albums/zz42/Brad_099/
              Hi guys,
              what's supposed to happen is this:-
              Turn the key and just the tail light comes on.
              When the engine starts (more accurately, when the alternator starts making current) a relay turns the headlight on.
              The relay locks so that the headlight stays on until the key is turned off even if the engine stalls or the alternator quits.
              If either of the headlight filaments fail the RLU turns the white warning light on and switches to the other filament.
              If it's the hi-beam burnt out the RLU simply switches to the lo-beam.
              If it's the lo-beam burnt out the RLU switches to the hi-beam but at a reduced voltage.
