fuel light not working.
  • skipper808
    • Aug 2003
    • 5
    • Kauai, Hawaii
    My fuel light is not working. The gas tank could be empty but
    fuel light will not come on. Is there a way to test this problem?
    thanks.
  • dragxs11
    • Jun 2003
    • 519
    • Reno, NV
    you did check the bulb in the tach, didn't you? If so, you can jump out the switch at the connector near the back of the tank to see if the switch is bad.
    Matt
    1980sg-Stocker-- Sold
    1980sg- Cruise Missile- Sold to RODS454
    1990 ATK 604- Ditch Digger
    2005 BMW K1200S- Killer Bee
    2005 Suzuki GSX-R 1000- trackbike
    • skipper808
      • Aug 2003
      • 5
      • Kauai, Hawaii
      If it is the bulb can I get it at any parts store? And If its the switch
      how do go about changing it. can it be tested with a multimeter.
      Thanks, Vince
      • dragxs11
        • Jun 2003
        • 519
        • Reno, NV
        Yeah, the bulb is available probably even at Walmart. It's most likely that it's burnt out. You'll have to unbolt the tach by the two nuts underneath(not too easy to get the inner one back on). There will be enough slack in the wires to pull the guage out, and the bulbs are held in by rubber. I would swap it with the neutral light and hit the key switch to see if it works. If it's not the bulb, we'll talk about the switch. I don't want to water your eyes too much.
        Matt
