fork tubes
  • malloryduck93
    • Apr 2010
    • 11
    • towanda pa
    fork tubes
    does any body know if all the xs 1100 take the same fork tubes
    Definitley the wrong section of the forum for this question, but the answer is that they do not all take the same fork tubes. The mounts for the calipers are different for some, and there is the difference for air shocks on the later model Specials. You can cross-reference parts between the years/models with the info on benefiscal.co.uk. Lots of info there, with pictures for most XS11 parts.
    • malloryduck93
      • Apr 2010
      • 11
      • towanda pa
      fork tube
      sorry i am a little new at this site i was wonder about just the top tubes not the whole fork assemble
        Apparently there's internal differences between the special and the standard that prevents swapping parts (I asked this question). So you can use any standard fork tube on any standard, and any special tube on any special, but no mixing.
        '78E original owner
        • malloryduck93
          • Apr 2010
          • 11
          • towanda pa
          fork tubes
          so as long as its out of a special any year will work
          • tinman905
            • Aug 2007
            • 946
            • Orangeville,Ontario ,Canada
            That is correct.
            BDF Special
              • 8863
              I've tried swapping the parts between the two, they'll fit, but they don't slide very well. Another member on here, can't remember who, has adapted Special tubes into Standard lowers.
              • mxmikie
                • Aug 2008
                • 482
                • Bouse az
                these are 37mm fork tubes........... 37 Honda CR-80R (96-98)
                37 Honda CR-80R (99-02)
                37 Honda CR-85R (03-04)
                37 Honda CR-125R "Elsinore" (79)
                37 Honda CR-125R "Elsinore" (80)
                37 Honda CR-250R "Elsinore" (78-80)
                37 Honda NX-250 (88-90)
                37 Honda XR-250R (81-82)
                37 Honda CMX-450C (86-87)
                37 Honda CX-500TC (82)
                37 Honda FT-500 "Ascot" (82-83)
                37 Honda VF-500C "Magna" (84-85)
                37 Honda VT-500C "Shadow" (83-84)
                37 Honda VT-500C "Shadow" (85-86)
                37 Honda XL-500R (82)
                37 Honda CB-550SC (83)
                37 Honda CBR-600F "Hurricane" (87-90)
                37 Honda CB-650SC "Nighthawk 650" (82)
                37 Honda CX-650T "Turbo" (83)
                37 Honda VF-700C "Magna" (84)
                37 Honda VFR-700F "Interceptor" (86)
                37 Honda CB-750F (81-82)
                37 Honda VF-750C "V45 Magna" (82-83)
                37 Honda VF-750S "Sabre" (82-83)
                37 Honda VFR-750F "Interceptor 750" (86)
                37 Honda CB-900C "Custom" (80-82)
                37 Honda GL-1000/K "Goldwing" (75-79)
                37 Kawasaki EX-500D1-D11 "Ninja 500R" (94-04)
                37 Kawasaki ZL-600A1/A2 (86-87)
                37 Kawasaki ZX-600A1-A3 "Ninja" (85-87)
                37 Kawasaki ZX-750A1-A3 "GPz" (83-85) 37 Kawasaki ZX-750E1/E2 "Turbo" (84-85)
                37 Kawasaki ZX-1100A1 "GPz" (83)
                37 Kawasaki ZX-1100A2 "GPz" (84)
                37 Suzuki RM-85 K2-K4 (02-04)
                37 Suzuki XN-85 D "Turbo" (83)
                37 Suzuki GS-500 EK/EL/EM/EN/EP/ER/ES/ET (89-96)
                37 Suzuki GS-500 EV/EW/EX/EY (97-00)
                37 Suzuki GS-550 LD/LF (83, 85)
                37 Suzuki GS-550 ED/ESD/ES3/ ESE/ EF/ESF/ESG (83-86)
                37 Suzuki GS-650 MD "Katana" (83)
                37 Suzuki GS-700 EF/ESF (85)
                37 Suzuki VS-700 GLPG/GLEPG/ GLPH/GLEPH "Intruder" (85-87)
                37 Suzuki GS-750 ED/ESD (83)
                37 Suzuki GS-750 LN (79)
                37 Suzuki GS-750 SD "Katana" (83)
                37 Suzuki GS-850 GN/GT/GX/GZ (79-82)
                37 Suzuki GS-850 GD (83)
                37 Suzuki GS-1000 C/EC/N/EN/ET (78-80)
                37 Suzuki GS-1000GT/GLT/GX/GLX (80-81)
                37 Suzuki GS-1100 ET/EX/EZ (80-82)
                37 Suzuki GS-1100 ED/ESD (83)
                37 Suzuki GS-1100 GZ/GLZ (82)
                37 Suzuki GS-1100 LT (80)
                37 Suzuki GS-1150 ES3/ESE/EF/ESF/EF2/EG/ESG (83-86)
                37 Yamaha XJ-650 LK "Seca Turbo" (83)
                37 Yamaha XJ-900 RK "Seca" (83)
                37 Yamaha XV-920 RH/RJ "Virago" (81-82)
                37 Yamaha XJ-1100 J "Maxim" (82)
                37 Yamaha XS-1100 E/F/G/H (78-81)
                37 Yamaha XS-1100 LG/LH (80-81)
                37 Yamaha XS-1100 LG/LH "Midnight Special" (80-81)
                37 Yamaha XS-1100 SF (79)
