Need to bleed.
  • draketrumpet
    • Feb 2010
    • 387
    • Norman, OK
    Need to bleed.
    So, after my rear brakes locked up on me yesterday, I decided I needed to bleed them in a bad way and clean my spooge hole while I'm at it. Looking over the manual/techtips it seems fairly straightforward if longish. I do have one question though, that will hopefully save me some time and looking like an idiot to non-XSsives. Where can I get nifty 3/16 in. plastic tubing to plug into my bleed valve. I know, I know, you're like, that's it, that's the question? Yep. I'm a noob so I have no idea. I'd probably go to autozone and they'd send me to lowes who would sent me to ace who would send me to salvation army to fill out a job app , at least I could quit school then
    TIA
  • CatatonicBug
    • 6117
    • Clinton, UT
    The first time I did it, I took the bled screw out and took it to a local hardware store. It wasn't a chain store though. I found the rack of tubing spools, and identified which size I needed.
    I'd say just about any good neighborhood hardware store should have a rack of clear tubing that will work.
    • draketrumpet
      • Feb 2010
      • 387
      • Norman, OK
      Just wanted to make sure
      the manual seems to indicate I can bleed without taking the brake off of the rotor. Am I understanding this correctly?
        If you drained the fluid from the MC and the brake caliper on the rear, it is a very trying process to bleed that system out. Most people end up using a mity-vac to get it bled out.
        • CatatonicBug
          • 6117
          • Clinton, UT
          If bleeding is all you are trying to do, yes, you can bleed it while installed. However, with your issue, you will be better served by removing the caliper, taking the piston out, removing the piston seals and cleaning BEHIND them. If you take the extra time to clean it thoroughly, you won't have to go back and do it again for another few years. If you take the short cut, you might get stuck again. A ounce of prevention is worth a pound of cure...
          Remember to take your Master cylinder off and clean all the internals in there too. Also remember to "bench bleed" the master cylinder, and prime the caliper by filling it with fluid before re-instaling. The more air you can displace with fluid, the easier it will be to bleed the remaining air out.
          • TomRodgers
            • Jun 2008
            • 492
            • La Porte Indiana
            JAT...im about to replace the rear caliper,m/c, and lines on the back of 'Sunshine.....i would think you could completely bleed the rear system off of the bike, with the caliper up in the air (above) the m/c to allow air to go in its intended natural direction...UP!!
            4:1 Jardine w/ headerwrap
            Windjammer(wiring issues)
            New paint/brakes to come!!
            '80G FrankenBike (parts bike)
            '80G to fix "BlackSunshine"
            Stock Pilots/125 mains
            Pod filters; 4:1 Kerker??
            SS Brake lines w/ new M/C's
            LED Brake Lite
            Needs paint....
              • 8767
              The rear brake can be a real PITA to bleed on these bikes. A vacuum pump is the best way to go. Another way is to hang the rear caliper down as low as it will go with the bleeder screw open. Have the cap of the MC off while doing this. Let it drip for a while, keeping an eye on the fluid level so it doesn't run dry. Then colse the bleeder, install the caliper, and bleed again by depressing the pedal. HTH
              • newc4
                • 605
                • Vienna VA
                Go to the local pet store and get some clear aquarium tubing. I've used it for years.
                Darrell
                Darrell
                78E
                80G project
                06FJR
                • XS1100 Newbie
                  • Jun 2009
                  • 1106
                  • Battle Ground, Washington
                  Amen to taking the caliper apart to clean. It is most worth it. If not, you may, and probably will be taking it off again and doing it. To many of us have tried the short way and failed, and brakes are a good thing to have on two wheels.
                  1980 XS1100LG Midnight
                  1991 Honda CBR1000F Hurricane
                  A cold beer and another one!
                  • BigRed
                    • Mar 2010
                    • 265
                    • Ottawa, Ontario, Canada
                    I'm looking at needing to do something to the brakes as well. I was just planning on flushing the fluid and moving the caliper pistons in and out a few times to see if that frees everything up. If I take the calipers apart, do I need to have a rebuild kit on hand to put them back together, or might I be able to clean and reuse all the parts?
                    The bike's been sitting for about 8 years. The brakes hold and release, but there is a lot of drag. I managed to free up all the drag by squeezing the calipers by hand and then tapping them with a rubber mallet. I don't want to need to try that while I'm riding
                    Thanks
                    '80 SG with motor from a '82 XJ
