*&^%*%& Connectors!!!!!!
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    Ok, anyone have any tips on how to remove the pin and socket type connectors from the plastic housing. These are the type like are on the handle bar switches and the RLU.
    I bought the stupid tool from the electronics store and it is worthless, I spent at least an hour last night trying to get just a single pin out and failed. The tool I have is like a tube with a center rod that you can push down with you thumb. It seems to fit ok on the connectors but for some reason doesn't release them from the plastic housing.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
    Yeah, these can drive you crazy...
    I've found that while pushing the tool onto the pin, you also have to push the pin into the socket from the other side as far as it will go. Wiggling the tool helps too.
    '78E original owner
    • clcorbin
      • Jan 2010
      • 495
      • Albuquerque, NM
      Also, one size does NOT fit all. The bore of the tool has to fit the pin fairly snugly or it won't be able to compress the barbs that hold the pin in the connector housing. I have three different size of those tools here and they cover most of the connectors I work on.
      The advice to push the pin up at the same time you are pushing the tool down is good advice. Sometimes the pins can get loose in the housing and the tool can't compress the barbs enough.
      -- Clint
      • psycoreefer
        • Feb 2008
        • 1557
        • Minden, NV
        Yeah, I tried pushing the pins in from the back, while pushing the tool in from the front, really need about 4 hands to actually perform that maneuver.
        Any chance you know what "size" those pins are? I brought the RLU into the shop with me and the guy looked at his rack and picked out this tool, so I'm assuming he picked out the right size. It does seem to be a fairly snug fit.
        Guess I'll keep fighting it when I get home.
        My Bike:
        [link is broken]
          • 8863
          If you're referring to the kind of connector with the little tabs, I always use the smallest flat head jewelers screwdriver from one of those cheapo sets. Kind of a PITA, but it works.
          • psycoreefer
            • Feb 2008
            • 1557
            • Minden, NV
            yes the kind with little tabs, but I think your thinking of the "flat" blade types with a single tab on the top. These are round, kinda like a bullet connector and have 2 tabs on opposite sides of them. what a PITA!
            My Bike:
            [link is broken]
              • 8863
              Yep, sorry I was thinkin' the flat type. I've never tried taking those round ones apart.
              • CatatonicBug
                • 6117
                • Clinton, UT
                I use a pair of pointy tweezers. Locate the tabs and grasp both sides with the tweezers. Then push toward the tweezers to be sure the tabs aren't stuck on anything, then pull the metal pin out of the plastic connector housing while wiggling in circles. It's not perfect, but I re-wired my trunk that way, using the same kind of connectors:
                • jmyers40
                  • 41
                  • Indiana
                  definitely not fun
                  I made my own tools out of a $5 pick set I bought at Menards or somewhere like that. It came with several different styles (straight/flat, hooked, hooked/flat, etc) and I used a grinder to make them fit in the littl boogers. If you break one, you're out a fraction of a dollar.
                  I wish I had known there was a specific tool for them. There's no electronics stores in my area.
                  79 XS1100 Special - slowing breathing life back into it...
                  • b.walker5
                    • Feb 2009
                    • 1745
                    • Invercargill, New Zealand
                    Your Molex Pin Extractor (the round one) should work fine. Make sure it fits the pin nice and snug and make sure its pushed all the way down. As already suggested push the pin in from the back until the tabs are released and then push the centre pin of the Molex tool. Dont pull on the wire ! The biggest mistake people make is trying to pull the pin out by yanking on the wire before the tabs are released. All that does is bend the tabs backwards and then the tool cant release them. Just take your time and make sure the tool is seated and you shouldnt have any problems.
