Ign. switch....in pieces
  • brcree
    • Mar 2010
    • 388
    • S.C.
    Hello all.....great forum here! I just picked up a ign. switch for my 81 1100 but its all apart. Does anyone have a blow up break down pic i can go by to put it back togethe?
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
    • 8863
    Pics of the ign. switch....
      Random Reinforcement works Best
      bikerphil,
      There. Right there!.
      If there's any reason why I keep logging in and reading every single thread/post/reply it's cause sometimes, hidden in plain sight, guru's like you put such jewels of wisdom/knowledge out there for any seekers to find/use.
      My usual reaction (this time as well...) is, just where did he find that??!
      How do he know all this stuff??!!
      Don't answer that Phil... I know it would be something along the lines of:
      "How is it that you do not?"
      <headdesk>
      • brcree
        • Mar 2010
        • 388
        • S.C.
        Ign switch
        Way cool Phil.....jigundo help man!!!!!!
        At this time:
        1985 Goldwing Innr.
        2007 vtx 1300
        81 sx 1100 s h
        81 sx 400 special
          That is one heck of a tech tip there Phil!!! Very nice!! Been into one of those several times and never figured out how to get the tumblers out.
            • 8863
            It took me a while to dig that one out of it's grave, not my tech tip though. I can't even remember where I found it, lol.
            • brcree
              • Mar 2010
              • 388
              • S.C.
              ign. switch.........P.S.
              I should put this bit of info in here about the switch.....there is a small white plastic piece that goes in last i think...I believe its for the fork lock....not sure. This piece has a small triangle shape on one side.
              At this time:
              1985 Goldwing Innr.
              2007 vtx 1300
              81 sx 1100 s h
              81 sx 400 special
                • 8863
                Did you figure out how it goes?
                • brcree
                  • Mar 2010
                  • 388
                  • S.C.
                  ign switch
                  Not yet.....I tried to put it in the base plate that is still on the bike...but it doesn't seem to fit there aswell....I know this came with the switch!
                  At this time:
                  1985 Goldwing Innr.
                  2007 vtx 1300
                  81 sx 1100 s h
                  81 sx 400 special
                  • brcree
                    • Mar 2010
                    • 388
                    • S.C.
                    ign parts
                    Got it!!!!!!!!...........Looken at the fork lock mechanism area you will see a silver piston at the bottom of the opening. The piston is in a metal housing with a flat horizontal area above it. Using a flat screw driver push down on this piston housing while inserting the white plastic cam piece. And Bobs your uncel!!
                    At this time:
                    1985 Goldwing Innr.
                    2007 vtx 1300
                    81 sx 1100 s h
                    81 sx 400 special
