starting motor gear stripped
  • dsweeney
    • 3
    • Dayton, OH
    Hi. A while ago I got some water in the engine, and tried to start it and the starter stopped working. It kick starts just fine. I just took the starter motor out yesterday to find the main gear on the starter motor side, connecting to the engine, had lost all of its teeth. The starter spins just fine when I press the start button, just no connection to vroom.
    I've looked around the online stores this website links to and have had no luck locating a dealership that carries this starting motor gear. Anyone have any other suggestions, like other bikes that would have a similar part?
    Thanks much.
    Deacon
    '79 XS1100F
  • randy
    • Dec 2003
    • 4521
    Check the condition of the idler gear in the engine. If it's also stripped (likely), don't bother replacing the gear on the starter. Keep kicking it till you're ready to split the cases. You can get used starters on ebay.
      • 2070
      1?...
      ... Where did all the metal from the teeth go?
      • GAXS1100SH
        • Dec 2009
        • 84
        • Peachtree City, GA
        Try Here
        If you are looking for part # 2H7-15512-00-00 then look here they have one.
        Hope this helps,
        Thanks, Steve
        1979 XS1100F stock airbox, Mikes XS Honda 750 Bars,
        68,000 miles and counting
        New to me
        1979 XS1100F, with Tour Package, work in progress.
        80,000 miles and soon to be growing.
          I bet if you look long enough and carefully, you can find a complete starter motor for less than that part on fleabay.
          • Mr.Bill
            • Aug 2009
            • 118
            • Clarksburg Maryland
            like this
            1979 XS1100SF.
            "You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOL
