In trouble.......
  • brcree
    • Mar 2010
    • 388
    • S.C.
    In trouble.......
    Some idiot broke off the tips of two idle needle bolts...(the ones set by the factory ). I have a 81 sx 1100 sh. It's the ones ontop of the carb opening and has a small spring between the bolt head and carb. body! Are these still around or will I have to count on ol ebay?
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
  • Crazcnuk
    • 2980
    • Hinton, AB, Canada
    They are still around. You can get complete carb kits still from various places.
    Georgefix on Ebay sells kits, and MikesXS on the net also sells kits and individual parts.
    To be more help we need to know the year and model you own, and what series carbs are on it.
    '05 ST1300
      If they're bolts......yes, you are in trouble!......joking. Do some thread reading and tech. tip reading here. Easy fix if you READ first. And yes, replacements availible besides the Bay. Someone here will be able to post links, etc. as it hurts my head to have to figure out how to paste all that info for you. Gather info here before you jump in with both feet......will keep you happier and your scoot will like you better for it.
      • brcree
        • Mar 2010
        • 388
        • S.C.
        in trouble
        I have a 81 sx1100 sh......just took a look at carbs....didn't see any no.s on them but Mikuni Kogyo on the side.
        At this time:
        1985 Goldwing Innr.
        2007 vtx 1300
        81 sx 1100 s h
        81 sx 400 special
          Are the idle needles down in a tunnel or is the head exposed. This will help determine which carbs you have.
            mikesxs.net
            www.mikesxs.net
            DO NOT ask them or tell them it's for an XS11, they want to only sell to 650 owner's, and their liability prohibits them from recommending any other fitment!
            Fuel Idle Mixture Screw with spring, washer and O-Ring Fuel Idle Mixture Screw with spring, washer and O-Ring - Fits: XS650G/H/SH/
            SJ/SK/SL (1980-84) with Stock Mikuni BS34 CV Carbs.
            See following 48-5012 text. Part #48-5011 $10.00 USD Ea
            At least now you know what you're looking for. This is found in the Fuel section, Pilot Screws.
            • Yard Dogg
              • Mar 2010
              • 884
              • Tri-Cities, Wa
              Here's a few places I've ordered from.
              http://www.carbkitscapital.com/carb_...a&model=XS1100
              • brcree
                • Mar 2010
                • 388
                • S.C.
                In trouble
                Ok Phil.......the heads are above the tunnels.......and thanks to all the great info folks, new to the SXer's.......long time bike restorer.
                At this time:
                1985 Goldwing Innr.
                2007 vtx 1300
                81 sx 1100 s h
                81 sx 400 special
                • tarzan
                  • 1700
                  • Chandler,Az.
                  If the heads are above the tunnel then you have carbs off of a '78 or '79
                  '80 and '81 have the screws inside the tunnel.
                  And this makes sense because the late model carbs don't break off like that.
                  At least I haven't seen that. I have seen broken tips in early carbs though, in fact I am guilty to breaking one off myself.
                  80 SG XS1100
                  14 Victory Cross Country
                    Ok, you have the 78-79 early type carbs on there, the mixture screw for those is a bit expensive ($15 ea.), looks like a rebuild kit for a whole carb including that screw is also $15 from carbkitscapital, might be better off taking that route, unless someone has a few spares laying around.
                    • SFSPECBIKER79
                      • Jul 2008
                      • 403
                      • NC
                      i have those
                      just send me pm, for the price, cheaper than new.
                      79 xs 1100 spec & 80 xs 1100 g
