Stupid move #33 - Petcock Lever
  • randy
    • Dec 2003
    • 4521
    Ok, I sometimes tear down faster than I should. Then I don't remember little details like this. This 'O-ring', which isn't an o-ring at all, rather it's a lipped seal. Lip in or lip out?
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    I put mine together lip out, lip in I couldn't get it to slide into the darn petcock body. Doesn't mean its right, but my petcocks don't leak so it works....
    Is that the lever out of a "standard" petcock? If it is good job filling the crescent hole....cant' even tell where it used to be.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
    • randy
      • Dec 2003
      • 4521
      yep, seemed to me that it would seal better lip in, but it seems impossible to do! Yes, that is a standard lever with the solder mod. Used a special solder for aluminum and cast zinc / alloys. Now i have an "OFF" where the "PRIME" used to be and no more vacuum diaphram horrors. BUT, I will also have fuel pouring out if I tip over . Guess I'd better not tip over
        • 8672
        Awesome, yep I put the lip out also. What is the special solder called?
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          Did you knock it out after you filled it then JB-weld it back in? Or is that good solder going to be one with the lever forever?
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
          • randy
            • Dec 2003
            • 4521
            It's called 'Aluminum Solder'
            No need to knock it out, don't think I could. It's in there for good.
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              Any special prep, scotch brite the surface, wipe clean, then brush on flux and then solder? Any special flux or will any due?
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              • randy
                • Dec 2003
                • 4521
                Like anytime you solder, the work must be clean. And, since it's a special solder, it has a special flux.
                Here's a link to the one i bought:
                • vanhump
                  • Feb 2004
                  • 142
                  • the virginia mountains CRAIG COUNTY
                  Randy,
                  The lip on a seal always faces the liquid , gas or what ever it is to seal off. They will sometimes work for a long while if in backward and there is not much pressure, but if there is much pressure build up they usually leak sooner than later.
                  POTTS CREEK EXPRESS
                  IF YOU AINT THE LEAD DOG
                  THE VIEW IS ALWAYS THE SAME
                  1980 G Full Dresser
