special pads, left? or right?
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    OK, so specials have "left" and "right" pads. I'll admit I wasn't paying much attention when I put the pads on, I've never worked on anything with different pads left and right... Anyways, how do I know which pads are the "right" side ones and which ones are the "left" side ones. Either pad can go on either caliper....
    And don't just say to match them up with the old ones because I don't trust the PO, he could have put them on backwards 10 years ago or whatever....
    1979 xs1100 Special -
    My Bike:
    [link is broken]
  • mack
    • 2411
    • Ontario, Canada
    pads
    Don't think it makes a difference with the rears. There identical. Fronts are sloped. One pair together make a flat surface. Just orient the holes they swivel on. Really can't go wrong
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • mack
      • 2411
      • Ontario, Canada
      Sorry
      After I read that it may have seemed insulting . As the pads sit in the caliper as if the they were to be fitted on the rotor, the thin edge should be closest to the piston side.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
      • CatatonicBug
        • 6117
        • Clinton, UT
        On mine, like te XJ, the rear is sloped too. When the pads are pressed together, the line between them looks like \. The line beween the front right pads, when pressed together looks like /, and the left front looks like \. HTH.
        • xs11lover
          • 1433
          • Montoursville Pa
          I was wondering about that myself...mack, I just about can understand...bug, you lost me.
          79 XS11 Special (Lazarus)
          79 DT 100
          • psycoreefer
            • Feb 2008
            • 1557
            • Minden, NV
            You can go wrong though, as bug posted one set of pads is cut / and the other set is cut \ so if your looking down from the handle bars you could put it together \ tire / or / tire \ the pads will go together either way, but I'm sure one is the correct way and the other isn't. Its not mentioned in the manuals so.....
            My Bike:
            [link is broken]
            • psycoreefer
              • Feb 2008
              • 1557
              • Minden, NV
              OK so a picture is worth a thousand words right,
              This picture is how bug says his look, \ / , its also how my old ones came off so I'm going with that for now... wish we could get a definite answer...
              My Bike:
              [link is broken]
              • CatatonicBug
                • 6117
                • Clinton, UT
                Yes, that is correct for the Specials' front pads. They really can only go on one way - you can't get them on if they are incorrect.
                Except, on the LH, they are shaped like this:
                • mack
                  • 2411
                  • Ontario, Canada
                  Pads and Calipers
                  Yep, clear as mud. Ok picture is worth a thousand words.
                  This should help.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • xs11lover
                    • 1433
                    • Montoursville Pa
                    Ok mack, so to put it in terms we can all understand. The thin edge (when on the bike) points front on the piston side and fat points front on the wheel side. Thin out, fat in.
                    Right?
                    79 DT 100
                    • mack
                      • 2411
                      • Ontario, Canada
                      Yep
                      Yep, that's about it.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
                      • xs11lover
                        • 1433
                        • Montoursville Pa
                        thanks, I'm happy to say that is the way I did it. Now if my carbs ever get here I can put them on and go for a ride!
                        79 DT 100
