New Jets...
  • TomRodgers
    • Jun 2008
    • 492
    • La Porte Indiana
    New Jets...
    As info...
    Just ordered new pilots and mains from BikeBandit.com They also stock genuine Mikuni jets.
    'Ghost and 'Sunshine will be getting the new 45 pilots and 140 mains put in soon, and back to Carb/Color tune....even though they run now, im betting with the other mods, it will be lean on the top end....
    still gotta get the damn brakes working...
    '81H (my first XS ) "Grey Ghost"
    4:1 Jardine w/ headerwrap
    Windjammer(wiring issues)
    New paint/brakes to come!!
    '80G FrankenBike (parts bike)
    '80G to fix "BlackSunshine"
    Stock Pilots/125 mains
    Pod filters; 4:1 Kerker??
    SS Brake lines w/ new M/C's
    LED Brake Lite
    Needs paint....
    Originally posted by TomRodgers
    As info...
    According to your signature, your bikes are 80-81. Do you have the early style carbs on them now? Those mains are waaaay too large for the later type carbs, aren't they?
    • TomRodgers
      • Jun 2008
      • 492
      • La Porte Indiana
      not sure...read thru the "carb jetting" stuff and all the formulas claim that should be good.... The 125's seem a bit lean (plug color)
      LED Brake Lite
      Needs paint....
      • TomRodgers
        • Jun 2008
        • 492
        • La Porte Indiana
        Carbs are later models...not the early style.....
        LED Brake Lite
        Needs paint....
          Ok, if you have 125's now, going to 140's would be 6 sizes larger. They go up in 2.5 increments. Your float level might be too low, JAT.
          • TomRodgers
            • Jun 2008
            • 492
            • La Porte Indiana
            ill have to check that out....
            i was just going by the thread about... increasing jet sizes based on certain mods...
            stock was blah blah blah...pods you add so many, 4 into 1 you add so many. based on those numbers, you increase pilots and mains....
            From 125 you have 130 135 and 140....3 sizes
            i had 125's laying around for some reason....110's were the stockers. I am relatively new to the whole "carb tuning" so i will be sure to check it out (float height) and also plug color....12 bucks for a set....if tooooooo rich, i will try 130's and see what happens....
            LED Brake Lite
            Needs paint....
            • psycoreefer
              • Feb 2008
              • 1557
              • Minden, NV
              I think that thread causes a lot of confusion....
              Stock size is 110's, according to you.
              +2 for a 4 to 1 exhaust
              +3 for pods
              = +5 sizes, now if you keep reading it says subtract 1 = +4 sizes.
              Also if you keep reading it says +1 pilot for each 3 main, so you may need to +1 pilot jets as well.
              110 + 4 * (2.5) = 120 mains.
              Actually you have 125 ->127.5 -> 130 -> 132.5 -> 135 -> 137.5 -> 140 = 6 sizes, the increments are 2.5.
              And remember those recommendations are just a starting point, you'll have to tune up and down according to your plugs and how it actually rides.
              1979 xs1100 Special -
              My Bike:
              [link is broken]
              • GARTHXS
                • 1631
                • Seattle
                what I have
                I run pods on the 78 with fj carbs but they are jetted like late model xs carbs, I think 120 mains like they said above floats may be the issue , what is your float height
                91 kwaka kz1000p
                Stock
                ( Insert clever quote here )
                • Yard Dogg
                  • Mar 2010
                  • 884
                  • Tri-Cities, Wa
                  I'm glad you said that, I was looking at mains the other day and wasn't sure if the sizes I was viewing were up 1 size or 2 or 3. Increments of 2.5, helpful.
                  Tomrodgers, My stock main jet is 140, not sure if it helps, but that's what's in my book and on the bike. Of course you have an H, I have an LG, not sure of all the differences. Did you ever chop test it with the 125s to see if it was burning right?
