gas line
  • slow mo
    • 858
    • ontario canada
    gas line
    hi all! i have just installed pods and now need some really good gas line ! can anyone recommend a type or brand? as i don't want to use my old line ,,thanks ,,ride safe slow mo!
    moemcnally@hotmail.com
    i AM THE KING OF NOTHING
  • oseaghdha
    • Aug 2006
    • 1075
    • N43.02.5,W88.14.2
    Tygon.
    But I don't know where to get it in Canadia.
    XS1100SF
    XS1100F
    • TomRodgers
      • Jun 2008
      • 492
      • La Porte Indiana
      OH BOY.....Seem like this has come up several times... Tygon is the $hit.....but you can get ALLLLL kinds off of ebay or any parts store...solid colors, transparent colors....its a personal choice really. you can even get stainless steel lines if you like. Some prefer to have line that you can SEE the fuel moving thru to make sure its there.... Just do yourself a favor, and purchase a decent set of in-line filters. Meaning DO IT cuz it doesnt take much to make your carbs have indigestion!!!
      4:1 Jardine w/ headerwrap
      Windjammer(wiring issues)
      New paint/brakes to come!!
      '80G FrankenBike (parts bike)
      '80G to fix "BlackSunshine"
      Stock Pilots/125 mains
      Pod filters; 4:1 Kerker??
      SS Brake lines w/ new M/C's
      LED Brake Lite
      Needs paint....
      • TADracer
        • May 2006
        • 1417
        • Kenner, Louisiana USA
        Well, at the risk of getting a barrage of comments, I just use plain old reinforced black automotive fuel line. Granted, it is not pretty blue or yellow and you cant see the fuel in the line but then, its cheap, works well, is not to worried about UV, doesnt get brittle and last for about 5 years or more before it gets ratty and needs to be changed.
        Mike Giroir
        79 XS-1100 Special
        • CatatonicBug
          • 6117
          • Clinton, UT
          When I first got my bike, the fuel lines were old and didn't want to stay attached without a clamp on them. I went the cheap route and got the standard auto fuel line from Advance Auto Parts. It seemed to work great for about ONE SUMMER! After that, the lining started to crumble every time I disconnected the line from either end. It probably would have been fine on a cage, where you intall it and NEVER move it, but when you're taking the tank on and off, adjusting carbs, etc., that black stuff just doesn't cut it!
          I went to O'Reilly, and spent $25 on 10 feet of Tygon line. It's supple, transluscent yellow, and it stays without needing clamps (though I did install them just to be on the safe side). I recommend the Tygon over the black stuff any day!
          • Yard Dogg
            • Mar 2010
            • 884
            • Tri-Cities, Wa
            Now that O'Reilly has bought out Schucks over here, maybe they can get me some tygon line. I keep having to buy gas line out of the lawn mower section. It works okay though I guess. It doesn't get brittle right away and seems to be holding up fine. It probably won't last over a year.
            • dbeardslee
              • Nov 2007
              • 4385
              • Maineville, OH
              I've got to agree with TADracer - I too have had good luck with regular automotive fuel line. Never had a problem with it crumbling, but then again I always run line filters. Speaking of which, regardless of the kind of line used, in-line filters provide excellent prophylaxis for the fuel system, so don't forget the carb-condoms .
              • slow mo
                • 858
                • ontario canada
                tygon
                hi all! i just priced tygon fuel line here in Ontario and its three dollars a foot or so 25 feet,, seventy two bucks plus tax,,i,m buying for 2 or 3 bikes! any better prices in the states ?? thank you ,,ride safe ,,slow mo!
                • CatatonicBug
                  • 6117
                  • Clinton, UT
                  Nope. That's about right. I paid just over $2 usd/foot. Expensive stuff, but worth it, IMO. Maybe just do one bike at a time. I bought 10 feet, and replaced every piece (I have the Octy too), and have about 3 feet left over. You might not need quite that much.
                  • DELL82
                    • May 2006
                    • 260
                    • Houston, Texas
                    I talked with engineering at Tygon. They told me that my C-4040A was getting hard because the plasticizers were leaching out. I ask what tubing can I get that does not have plasticizers in it. Their response was C-210-A.
                    I ordered 25 feet from www.smallparts.com. Cost was $32.00 to me in Houston, TX. The tubing is clear and thin walled. It will crimp with a sharp bend. I will let you know if it works well.
                    Dell82
                    Dell82
                    Houston, TX
                    82' XJ1100J Maxim "LASERMAX"
                    SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
                    SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
                    SOLD 82' CB450SC Nighthawk, parts bike SOLD
                    • CA
                      • Feb 2009
                      • 267
                      • Nashville, TN
                      3 ft. for 5 bucks...
                      I just bought some fuel line at Oreiley's here in Nashville. It was translucent yellow and it is awesome stuff...so I am guessing it is what y'all call "tygon" haha. I believe it was 1.60 or 1.70 a foot.
                      Now if I could just get the floats to close...
                      1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)
                      • randy
                        • Dec 2003
                        • 4521
                        Mcmaster has all that oddball stuff,
                        McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                        • MrOzz
                          • Aug 2008
                          • 782
                          • Massachusetts
                          I used the MotionPro Blue fuel line. Not to bad. I ordered it from dennis kirk awhile back. Does seem to get a little stiff over time.. about 2 years now.
                          1980 XS 1100SG
                          Dyna 3 Ohm Hi Output Coils
                          Pod Filters
                          DynoJet Kit
                          T.C.'s Fuse Block
                          V-Max Auto CCT
                          • ManitoulinLad
                            • 358
                            • Manitoulin Island,Ont.,Canada this is in Lake Huron
                            Hey Mo: Thats what I got on my bike & the price you stated is about right. You can just buy it by the foot length. It is the cat's azz, you don't even need nylon ties to hold it on & it stays limp & you can undo it & it will seal back up just as originally. I've had it on for about a year now & god knows how many times its been taken apart & put back on with all my past carb cleanings etc & motor job & jsut took it off again for my petcock rebuild. Its worth the $$ & you really don't need that many feet if you measure it out. See ya in June at the boat - Dan
                            '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
                            1179 big bore kit, 80SG motor
                            Rebuilt head, valves
                            TC Bros Forward Controls (Brass Pegs)
                            Tkat Fork Brace
                            T.C. Spade Fuse Box
                            Dyna Coils & wires
                            Mikesxs shocks,controls,& bars (special)
                            ISO grips with stelleto ends
                            4 into 1 black Bassani exhaust
                            Bridgestone Spitfires
                            Tuned by Tinman905
                            & a will to keep it.
                              Lawn Mower Repair Shop
                              Hi Mo,
                              I can't be absolutely certain that this is "Tygon" line:
                              But I do know that it was available and cheap at my local lawnmower repair shop. They use it instead of the opaque black stuff. Seems like good fuel line is a common interest whether its for an XS or for the Briggs+Stratton.
                              I don't remember Cringing when they told me the price. In fact I bought 10 feet of it and walked out the door.
                              Did use the credit card though. Maybe would'a felt different if I had to actually count out the individual bills. I dunno.
