Error in clymer 11 manual
  • Filter
  • Error in clymer 11 manual
    Hey, not sure if this has come up before but I was re-building my front calipers on my SF today, decided to look up the section in my manual to verify I was assembling everything correctly and it shows the front caliper on the special assembled with the "o-ring" on top of the large flat washer that goes between the caliper and mounting point on the forks. That is not correct, I just looked it up on the yamaha parts fiche and the correct order from top to bottom is:
    nut, lock washer, caliper mount tab on the fork, Large washer, o-ring, caliper, small washer, head of bolt.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
  • #2
    Oh, that's one of many we've seen, we should try to list them all in one place, maybe we could start listing them here then a moderator could compile them into a tech tip?
    My favorite (not!) is the one in my 78 factory Yamaha manual. The swingarm pivot torque is listed as 76 ft/lbs. It's actually the LOCKNUT that gets 76 ft/lbs, not the shaft itself. DAMHIKIJK!
    • #3
      I noticed on page 61 Exploded View of the front forks has about 3 washers and spacers that my bike didn't have. It's not just cause it's a special instead of a standard either. Maybe I'm missing some things.
