jetting
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    Just an idea. I have a local shop that will let me buy one set of jets then swap them out for free if I need another size. I would talk to some of the local shops and see if they will work with you. However, I have about 5 different main jet sets, since I horde stuff and don't feel right swapping them 5 times without paying them at least something.
    Kinda neat when they start calling to ask if I have a spare set they can sell another customer and replace them for me.
    Ich habe dich nicht gefragt.
    • 81xsproject
      • 3185
      • Fortuna, CA
      Yep, those are the early type BS-34 II carbs (78-79).
      Don't know how I missed that.
      I would do 145/45, same all the way across.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • morrellxs
        • Oct 2009
        • 1
        • Kingston On Canada
        I am also going through the rejetting process and my question goes back to the variance between the mains in the inner and outer carbs. If 1 and 4 use 110 and 2 & 3 use 120 normally, would I use 120's or 130's in all the carbs?
        • tinman905
          • Aug 2007
          • 946
          • Orangeville,Ontario ,Canada
          I would try 120\'s across first and take it from there. 130 seems a bit too large .
          BDF Special
            They are the early carbs tinman, 120 WAY to lean. Needs to go with the Mikuni size stated by those who are running pods and similar exhaust.
            • tinman905
              • Aug 2007
              • 946
              I believe Tim\\\"s (rubyasaurus) carbs are the early model. morrellxs has popped in and asked another question .With his jet sizes I am only guessing he has later carbs.
              BDF Special
              • rubyasaurus
                • Mar 2010
                • 13
                • simcoe ontario
                were canadien carbs different (leaner)
                The bike is running great at idle and midrange now, I put in 45 pilot and 142.5 mains, the mains lasted about 2 min, bike ran like **** top end, so I went and bought a set of 1, 37.5s better but still a big sputter at 3/4 to full throttle, until the bike got up high revs. Put in 132.5 alot better now, the sputter is way better, but still there, stock is suposto be 137.5 but I am going to try 130s next.
                I dont know, according to most advice here 130s should be too lean, but my plugs are getting sooty now and the hesitation gets better everytime I go leaner.
                Thanks
                Tim
                1979 XS1100SF
                1983 maxim 650
                1987 elTigre 6000
                1999 mxz 600
                • dbeardslee
                  • Nov 2007
                  • 4385
                  • Maineville, OH
                  Tim - you do have the screws in place over the pilot jet towers, don't you? Leaving them off will cause a very rich condition. JAT
                  • rubyasaurus
                    • Mar 2010
                    • 13
                    • simcoe ontario
                    Yes thery are in, I must admitt, I tried it without them once, that did not last very long, beleive it or not it still ran, but i wont do that again
                    Thanks
                    Tim
                    Oh yah my outside plugs get slightly darker than the inside ones, I have not synced the carbs, yet could that be the colour difference?
                    Thanks again
                    1979 XS1100SF
                    1983 maxim 650
                    1987 elTigre 6000
                    1999 mxz 600
