final gear case grease - moly paste?
  • dontlikeoc
    • Nov 2009
    • 173
    • Alhambra, CA
    The manual says just use lithium base grease. But other shaft drive motorcycles such as Goldwing or BMW bikes specifically require use of solid moly(molybdenum disulfide) paste. Has anybody been using moly paste instead of lithium grease? I kind of feel it is safer to use the moly paste as it is designed to lubricate even when the grease/paste dries out. Could there be any harm using it instead of the lithium grease?
    Sharing of any thought or experience would be appreciated.
    dontlikeoc
    1981 XS1100 Special Edition
    Alhambra, CA
    I've got a ton of miles on just regular high temp bearing grease..
      Sorta ditto, I've got a 1/4 ton of miles, same grease!
        Originally posted by dontlikeoc
        The manual says just use lithium base grease. - - -
        Hi Dont,
        the manual also sez to pump it into the grease nipple to nowhere, right?
          True enough Fred...........till nowhere fills over the years and somewhat seperates allowing some lube to seep in amongst the splines.........hey, JAT.
          • tinman905
            • Aug 2007
            • 946
            • Orangeville,Ontario ,Canada
            Moly paste will adheres to the gears better/longer but any good bearing grease or a moly grease is fine with regular maintenance . If you can afford to use moly paste use it but you can probably buy 5 tubes of bearing or moly grease for the price of 8oz's of moly paste.
            BDF Special
            • dontlikeoc
              • Nov 2009
              • 173
              • Alhambra, CA
              Thank you for your replies. Sounds like that final drive lube is not a weak spot at alll. I wont worry too much about using the moly paste then.
              dontlikeoc
              Alhambra, CA
