Tire question
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    Yeah, the SF has a 16" rim, unless someone swaped it for the 17" like they did on mine. Make sure you get the spacers, caliper bracket, and torque arm thing of the special to do the swap, and remember the order of them. The pieces are a little different between the two.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      OK, I have made up my mind on what tire to buy. I am going with the Dunlop Elite 3. I looked at Dunlop's web site and they say the tire is MT90B16. I found the tire at motorcycle super stores web site and what they have listed is MT90HB-16, I think the H is the speed rating and the B is for black wall. I cannot find that model they have listed on Dunlop's web site. Does anyone know if its the same tire? Also where are you guys buying your tires? I want to use motorcycle super store cause they take paypal and I have some funds in my account, but if you know another site that you use that takes paypal that would be great.
      Their price is 109.99 with free shipping.
      Thanks again all for your help with this,
      Ozz
      1980 XS 1100SG
      Dyna 3 Ohm Hi Output Coils
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
      • MrOzz
        • Aug 2008
        • 782
        • Massachusetts
        Originally posted by psycoreefer
        You don't have to, but IMHO you should. Different tires could cause strange handling just like in your car, only worse because your not as protected on your bike.
        Why not buy another rear the same as the one you have now?
        The reason why is the one the P.O. put on when I got the bike is horrible. It always wants to kick out on me when its wet out. Its a Barracuda tire, which I believe is made by Cheng Shin.
        The front one does not seem to bad. It sometimes wants to follow a grove in the road.
        Ozz
        1980 XS 1100SG
        Pod Filters
        DynoJet Kit
        T.C.'s Fuse Block
        V-Max Auto CCT
          H is the speed rating and the B means Biased ply.
          As for the Superstore... you could take some time to look around. If you find the tire anywhere else cheaper, they'll match it. I've ordered quite a few from them.
            Originally posted by trbig
            You could get a 16" rim for it.
            I've thought about that but I have two Standard bikes right now: the '80G and a '79F for parts but no Specials.
            "Just one more thing!" <wry grin>
            Regards,
            Scott
            • MrOzz
              • Aug 2008
              • 782
              • Massachusetts
              OK one more question, lol
              I am contemplating on changing my own tires. The M/C shops around here are pricey and some will not do it unless I buy the tires from them.
              Those of you who change their own tires have you used something like this?\
              What do you use to balance the tries. I read a thread on here and is it as easy as a pole and a couple of supports?
              Just spin the tire slowly and mark the tire at the top, repeat then add the weights?
              Thanks all.
              If this is the case the it looks like I can do my own for about 3/4 of the price, then after that I have the equipment and can do it to save money. Well also the satisfaction of doing it.
              Thanks again all.
              1980 XS 1100SG
              Pod Filters
              DynoJet Kit
              T.C.'s Fuse Block
              V-Max Auto CCT
              • psycoreefer
                • Feb 2008
                • 1557
                • Minden, NV
                Nope, I use a pair of things looking similar to these you'll find em at most bike shops.
                For breaking the bead, which can be the hardest part I have a 2x4 screwed to the sill plate in my garage with a heavy duty gate hinge, put the tire on the floor next to the wall, place small block of wood next to the rim on the bead, use 2x4 as lever to push on block until bead breaks.
                For balancing I use the axle out of the bike and whatever happens to be convenient to support it on both sides. I've used chairs, blocks of wood, etc.
                Spin and mark the top, repeat several times, split the difference and add weight. spin some more, repeat till marks are all over the place. Most bike shops will have "sticky back" wheel weights you can use.
                First time I think my total investment including more weights then I needed and the hinge for my bead breaker was about 20 bucks.
                Try a google search for motorcycle tire mount and balance, you'll probably get lots of "how to's"
                My Bike:
                [link is broken]
                  In the second link you posted, is the setup you can buy at Harbor Freight. What you see pictured is actually the base, and the motorcycle attachment, each priced seperately. Just so happens, I went to Harbor Freight TODAY and bought that exact setup. They are normally 59.99 each ($120) but until the 27th, they're 10 bucks off each. ($100). I've used this setup quite a few times at a friend's house, so it does work. It's definately not commercial grade, but it will change you and a buddy's tires from now on. It's all manual though and still takes some work. It also needs to have the base bolted down to concrete or such.
                  For balancing, again from Harbor Freight,
                  http://www.harborfreight.com/cpi/cta...emnumber=98488
                  You can still make this on your own and use your axle and wheel bearings, but the bearings on this stand are MUCH more sensitive than wheel bearings. You'll have to close the garage door and shut off the ceiling fan. ANY breeze will mess things up.
                  Using this, you lightly spin the tire and find out where the heavy side is. You tape a weight to the opposite side that you think will work and lightly spin the tire again until it settles at the heavy point. Is the weighted side at the bottom now? Too much weight added. Weight still at the top? Not enough. This method takes a little time, but eventually, you'll spin the tire a bit, and it will keep stopping in a different spot.. meaning no heavy spot. Attach the weights permanently at that point that you have stuck with the masking tape.
                  For those thinking this sounds kinda Mickey Mouse, this works EXCEPTIONALLY well, and I've never had a computerized balance get anywhere close to what I can get with this method.
                  • draketrumpet
                    • Feb 2010
                    • 387
                    • Norman, OK
                    not that this helps you...
                    but I just found a guy in Oklahoma City that claims he'll mount & balance tires on the bike for $15 each, even if you bring your own tires. For those in the area, name is "Motorcycle Tire Store".
                    I'll take a trip once my new Shinkos from motorcycle superstore come in (not the best, but for easy touring/beginner riding on a budget, they should be great). I'll post if there are any surprises...hope not
                    • XJOK2PLAY
                      • 2099
                      • Skiatook, Ok.
                      Hey, Tod...
                      I read where the other day you mentioned that the E3 front was downright scarey in the wet...
                      What's the deal w/ them? Do they hydroplane easily, or do they just get kinda oily / slick & loose traction?
                      I ask, because so far I haven't rode much in the rain... the times I've had, I haven't noticed that. They seemed to be ok.
                      (FYI... remember I have a matched set of E3's...)
                      Someone a while back was complaining of the way the funneled water straight into the engine... but I haven't noticed that either.
                      So far, I love 'em after 10,000 miles. Sorry to tell ya, my front still looks like new... (I know you're hopin' yours wears out soon...) my back tire's starting to show some wear, but still has a LOT left... but I know I'm nowhere near as agressive on them as you are. (But I have worn the little teats off the sides... thank you very much...) LOL
                      Just wondered what your experiences were that made them 'scarey' ?
                      2011 Kaw Concours 14 ABS
                      • XSokieSPECIAL
                        • Jun 2009
                        • 1631
                        • Tulsa, OK
                        I got a Shinko SR712R on the rear and I LIKE IT.
                        I've also got access to a tire machine.....heh..heh...heh.
                        balance is $6 at the Yammy dealer.
                          Yup. The direction they have you mount these works good in the dry, but in the wet, it funnels and pushes water under the center of the tire instead of out and away like any other normal tire like on a car. I don't understand it. I even emailed Dunlop to ask them if it harms a tire to run it opposite of the directional arrow, and of course I got the standard "Do not operate tire other than direction stated." No answers to why, just a covering of azz.
                          So, if you haven't had any problems, great. Sounds like you'll get a ton of mileage out of it.. grrrrrrr.. lol. I may get another front tire and mount it on a rim.. use this E3 tire in the summer and another through the wet seasons.
                          • draketrumpet
                            • Feb 2010
                            • 387
                            • Norman, OK
                            Yeah, I did a quick search on Shinko. Apparently a Korean company that may (I can't substantiate this) have bought Yokohoma technology. One review I read said they were a great value and while they weren't top of the line, they were certainly adequate. Only complaint on the model the guy was reviewing (sorry, I forgot where I read it) was that the front tire seemed a little heavy and needed a good firm hand.
                            I got the 230 tour master pair (the only one's that were in stock and fit) and should get 'em on a week from Sat.
                              Yeah, I may be spreading rumors since I haven't actually read it, but I was told that is a fact.. that Shinko bought Yokohamas patents, tire molds, .. the whole shebang.
                              Hopefully they'll work out well for you. They are certainly supposed to be a VERY good tire on a budget. Hopefully better than the Cheng-Shins anyway.. lol.
                              • cywelchjr
                                XS-XJ Super Guru(Deceased)
                                • 4450
                                • Sacramento, CA
                                Frankly I don't think they could possibly be as bad as the Cheng-Shins. Those have got to be the worst tires I have ever put on a bike. I have a set on my 400 and I think I would have been better off with a set of mountain bike tires. Don't get me wrong, they grip ok, but they wear really badly and have really bad cupping problems, even on the back tire.
