Hello new to the forum and I have just picked up a 1978 XS11 and the turn signals are on all the time but do not flash. Any tips or suggestions ?
Turn Signal???
Correct wattage
Ensure that you have the correct wattage lamps in the turn signals. I think the correct lamps are 12 volt 27 watt if my memory serves me correctly. If the wrong wattage lamp is utilized, the flasher will not work. Also, check switches and grounds. I hope this helps.78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpg -
BUT it only takes a few minuets to open the control and have a look inside. Pretty simple switch.
Sounds like you may have some multi-meter testing to find the problem if it's not an obvious snafu. Do you have a wiring diagram?
Just not flashing is generally caused by "dirty" wire connectors/grounds and sometimes by a bad flasher. Every "new" XS I've had I spent a few hours just cleaning the wire connectors and fuse box. Saves time later if a problem should occur.
mroComment
