Uh oh
  • Fix
    • May 2009
    • 384
    • Lake Orion, MI
    Uh oh
    Well it finally got dry and warm enough in SE Michigan to ride the bike a little. And I do mean a little, cause about 5 minutes in, I hit the left turn signal and the tach, gas gauge, blinkers, and brake light went out. I still have the headlight and tail light.
    Any ideas what I broke?
    Mike C
    Lake Orion, Michigan
    '78 XS1100E
    Here I am! Where are you?
  • XSokieSPECIAL
    • Jun 2009
    • 1631
    • Tulsa, OK
    Check your fuses bro'. There must be a short in the TS wiring somewhere.
    • tinman905
      • Aug 2007
      • 946
      • Orangeville,Ontario ,Canada
      I had the identical problem with my bike last year. I took my left side switch apart cleaned it, lots of corrosion everywhere. After that no more blown fuses, problem solved
      BDF Special
      • Fix
        • May 2009
        • 384
        • Lake Orion, MI
        Thanks gents, I'll check that out after work today.
        Mike C
        '78 XS1100E
