Factory valve shim thickness?
  • Yard Dogg
    • Mar 2010
    • 884
    • Tri-Cities, Wa
    I'm just wondering if anyone can tell me what sized valve shims come stock in a 1980 XS11 midnight special? I want to order the valve shim kit from bike bandit but am not sure what diameter they are or what thickness I need to order. It looks like on the drop down order list I need to select a range of thickness and the outside diameter. My bike has low miles and has probably never been re-shimmed.
    Just like every crank and rod bearing, or cam journal, each bike is unique and none will have the same shims. You'll have to measure the gaps of what you have, then remove them and see what sizes you'll need.
    • Yard Dogg
      • Mar 2010
      • 884
      • Tri-Cities, Wa
      Right on. I thought I might hear something like that. What about the outside diameter?
        They make a 29.5mm shim for some bikes. You can't tell the difference by looking, or even holding next to a 29mm, but it won't fit in the shim bucket. The ones you need are 29mm.
          • 8930
          Another supplier for valve shims, BB is usually expensive....
          • Yard Dogg
            • Mar 2010
            • 884
            • Tri-Cities, Wa
            Thanks I just bookmarked that page.
            • Guy_b_g
              • May 2007
              • 790
              • Beverly Hills, Florida
              Use this source:
              We have our own shim library.
              Guy
              '78E
              • clcorbin
                • Jan 2010
                • 495
                • Albuquerque, NM
                He he he! I was just hit with a 29.5mm shim this week. I took a pair of shims down to the local bike shop to trade in for the needed thickness. One of the "new" ones turned out to be 29.5mm. I didn't know until I tried to put the other shim in. It just wouldn't fit!
                It was only only when I pulled it back out that I noticed that it didn't feel right. You might not be able to see the difference between the 29 and 29.5 shims, but they do feel different in your fingers. Thankfully, I didn't have any issues getting it exchanged for the correct shim, but it DID cost me an hour to drive to the other side of town and back
                -- Clint
