Having a bad day
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    Having a bad day
    while tightening the pinch bolts on the forks I had 41lbs instead of 14lbs in my head and you guessed it snap.
    these seem to be a special shear type.
    Any suggestions as to where to source some?
    Replaced front wheel bearings and they seem very tight.
    I only hit the outter races when installing them.
    Any suggestions would be appreciated.
    Rick
    650SF
    XS1100SG Project bike
    • 7831
    Ace hardware should be good for them. Just replace the bolt with the allen cap screw, as it's a little harder than the standard bolt.
      • 8930
      Ace has those metric studs too. I assume you're working on a Standard.
      • Rickrod3
        • Jun 2009
        • 721
        yes got some bolts athe the hardware. I was just a little concerned that the stock ones seem to shear when over tightend. I believe its to protect the triple tree it shouldn't be a problem unless I get my torque settings backwards.
        It won't happen again.
        Rick
        650SF
          • 8930
          Oops, misread your post, thought you were referring to the axle pinch studs. Glad you got it sorted out.
