OK, so i bought an overly abused 78 XS1100, with my divorce it was cheep, it ran and i needed something to do in my spare time as well as I needed something to get away. when i got it , it had two fog lights for the headlight, it had no turn signals and it bogged when u tried to accelerate heavily and a tiny gas leak. i got it late in the year, so i got everything adjusted, calibrated and running OK. The gas leak was slight and never when it was running, just sitting. so i rebuilt the petcocks or tried rebuilding them (the k and L set i got didn't do much i think its for and 79 special) by that time it was end of the season, so i put it away. the last two days i was getting it ready for the road, i got gas put it in and in 2 mins the gallon i put in to get it going was emptied into the air box and on the ground.
Today, i went to adjust floats and look at the seats and needle valves. Much to my horror, the P.O. broke the float post off in number two ( second from the choke) and repaired it with J.B. weld. and had the needle valve in upside down in the first carb. all the valves are clean and new looking and i cleaned everything out, but the #2 post had weld broken and had bits in the bowl, and the float pin was glued in place with the remaining, need less to say i am up set, but the trouble is i now need to find a replacement carb or body, i have looked on line and no one sells them as a single, and with my divorce and recently losing my job, 400- 500 hundred is more than i can afford. With the current low paying job i have . So any tips n tricks to fix, or even if someone has a spare carb or carb body i can buy? any help will be appreciated. i can see using J.B.weld, but not in a wet environment!
here is a pick its a bit blurry but it shows what they did!
