This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
Sure, I'll bite. I don't think anyone has used FJ carbs that I can remember. Try a search with the search tool at the top of the page. The first step would be finding out the spacing on the FJ carbs, if it isn't the same (or close) as the spacing of the xs carbs your in for alot more work. I think the most popular swap is GSXR carbs. Some where there is a thread with a bunch of carb links in it. If I can find it I'll post it.
1979 xs1100 Special -
Good luck, if you go through with it make a post so we can all learn from your work!
They fit better than stock, only mods are a handlebar choke lever, fuel inlet adapter, throttle cable setup, I think that's it and they should fit a stock airbox
