Petcock prime side sealing
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    I removed my octy awhile ago. I used these "fuel safe" nipples to plug the prime side of the petcock. Looking at the nipples I can see that they are starting to crack. Anyone have a idea on how I can seal the prime side of the petcock permanently? What I was thinking was a brass screw and some solder?
    Thanks all.
    Ozz
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
  • ManitoulinLad
    • 358
    • Manitoulin Island,Ont.,Canada this is in Lake Huron
    I just filled mine with JB Weld from the nipple side & kinda just shoved it up there & its been about a yr with no leaks. The tank was empty when I did that. - Dan
    '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
    1179 big bore kit, 80SG motor
    Rebuilt head, valves
    TC Bros Forward Controls (Brass Pegs)
    Tkat Fork Brace
    T.C. Spade Fuse Box
    Dyna Coils & wires
    Mikesxs shocks,controls,& bars (special)
    ISO grips with stelleto ends
    4 into 1 black Bassani exhaust
    Bridgestone Spitfires
    Tuned by Tinman905
    & a will to keep it.
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      The original formula JBWeld will work really well for that, but make sure you let it cure for the FULL 24 hours before putting gas to it. DAMHIK.
      • MrOzz
        • Aug 2008
        • 782
        • Massachusetts
        Probably more than 24 hours of curring for me. Tank and side covers are at the the painters. Last thing I need is gas all over my new paint. LOL
        1980 XS 1100SG
        Pod Filters
        DynoJet Kit
        T.C.'s Fuse Block
        V-Max Auto CCT
        • cywelchjr
          • 4450
          • Sacramento, CA
          As long as you do the 24, it will probably outlast the rest of the petcock.
            I used a short piece of fuel line with a bolt stuck in the end. I sawed off the threaded part of the bolt and used the shank.
              - - - Anyone have a idea on how I can seal the prime side of the petcock permanently? What I was thinking was a brass screw and some solder?
              Hi Ozz,
              that'd work, but like you say, permanent. But what if you change your mind?
              My cheap fix to seal off the prime spigot was a short length of genuine heavy-duty fuel hose with a ball bearing shoved up it.
              Plus no risk of you screaming like a girl when the molten solder drops onto your wrist.
              • oseaghdha
                • 1075
                • N43.02.5,W88.14.2
                Thanks all.
                Ozz
                I've had the same caps on mine for a least 2 years.
                Make sure they are neoprene.
                XS1100SF
                XS1100F
