Laid down now not starting
  • JKirk
    • Jun 2009
    • 1
    • Nebraska
    Last fall I laid down my '79 XS11 Special and all that seemed to be wrong was that I bent the handle bars and locked up the brakes so it's hard to push. A couple of days ago I finally got around to taking off the bars and popping the start button back into position. I turned the key and the headlights came on and the turn signals and brake light all work. But for some reason when I push the start button, NOTHING happens.
    Here's what I did to it when I laid it down. I was turning onto a main rode and hit a wet spot at maybe 10 mph or so. The bike slid on it's right side for about 30 - 40 feet. I'm pretty sure it died on it's own...but I might have had to turn off the key. The right side of the handlebars got bent almost to the tank and somehow the start button got stuck inside the box it's in. I don't think I ever turned the kill switch on. When I stood it up, everything else looked fine (thank God for the engine guards!) but it was hard to push... the neutral light is on but it feels like the brake is grabbing. Probably because of the bent bars.
    All the fuses are fine. Does anyone have any ideas on why absolutely nothing happens when I push the start button?
    Thanks!
    -Jim
  • Hepcat
    • Apr 2004
    • 190
    • Captain Cook, HI
    Jim,
    It's nice to maybe be able to help out another Cornhusker. (I'm from just East of Grand Island originally)
    First I think I'd be sure to check the wiring to the start button and make sure you didn't pull a connection loose or break a wire. Somebody else is sure to double check me on this one, but I think you can unplug the wire to the starter button somewhere and you should be able to use an ohmmeter and see a connection made when you press the start button.
    If you've got a connection there when you hit the start button, it may be the kill switch under the tank. When the bike tips too far while running, it'll cut power to the engine. When you get an impact, I could imagine the kill switch could get jammed in the tipped position. But I think the kill switch only disrupts the spark, not the starter...I've never checked that one.
    If you've got the ohmmeter out, you could always check that the kill switch isn't keeping the circuit open. I think that the kill switch will allow the starter to turn over though...seems like I can recall cranking my bike for an awful long time before I realized the kill switch was off.
    My guess is that it's a loose wire somewhere. Check your ground wires, anything that might have been suspect before could have gotten jarred open. Also check your fuses...
    Aloha, from a former Nebraskan!
    Jon
    __________________________
    Jon Groelz
    '82 XJ1100J-John
    '78 XS1100E-Name Forthcoming (It's a Girl!)
      • 1377
      Handle Bar Kill Switch?
      The kill switch on the handlebars will prevent the starter from activating/turning if it is in the OFF position. At least that's the way it operates on my 79 XS Special.
      If you say that you had to pop the starter button back in then I'd suspect that there may also be damage to this switch: they're right next to each other and likely suffered the same impact.
      Good place to start the hunt.
      • psycoreefer
        • Feb 2008
        • 1557
        • Minden, NV
        I agree pull out a multimeter and check your switches first.
        1979 xs1100 Special -
        My Bike:
        [link is broken]
        • Ken Talbot
          • 4251
          • Revelstoke, BC
          Chances are the tip-over switch activated when it went down. If it did, it might be stuck?
          Ken Talbot
            • 1377
            Plug-n-play...or NOT.
            The Tip-over switch is Normally Open. That is in order to kill the engine it has to make contact/complete a circuit. The the handlebar Kill switch is Normally Closed and has to open/break a connection to stop the engine.
            Click on the diagram to show it full size:
            Courtesy of member TopCatGr58
            Both switches also show that they each have a separate connector into the main wiring harness.
            Without a meter it's possible to just disconnect the proper connector for the Tip-over switch and try to activate the starter. If it starts or tries to then you'll know it was the switch.
            You can also plug the switch back in and see if it reproduces the "failure to start" problem.
            The handlebar switch requires a meter to test for continuity between the two red/white striped wires at the switch side of the connector. In the run position there should be continuity.
              I don't think that the tipover overrides the starting, just kills the ignition. I could be wrong though.
                Yep, looks like the tip over kill switch just shorts out the TCI from providing spark.
                Start with the easy stuff, jump across the large leads of the solenoid and see if the starter turns. If it does then the issue is most likely somewhere in your handlebar kill switch or the starter button. Both of which took a beating form what you stated. Or it could be the solenoid itself. Take a couple wires and jump the blue wire form the solenoid to the battery ground and the small red wire form the solenoid to the battery positive terminal, if the starter turns, then the solenoid is good. Trace power out from the fuse box on to see where you loose it.
                If not, then you may have pulled a ground wire loose somewhere. OR somehow killed your starter. It all gets fuzzy grey for me from there.
                  • 7765
                  If the kill switch is in the "off" position, the starter will NOT turn over! IF it's even just a little off the run, it may be OFF!! BTDT
