Jets??
    Jets??
    I was pulling my set of carbs apart today for rebuild/powdercoating and everything was fine except one of the pilot jets... had to easyout that one. So, can I get a replacement at most any Yamhonsukawa dealer, or are these hard to find?
    Thanks!
    '78E original owner
  • jmnjrpa
    • Jun 2009
    • 863
    • Lewisville, Texas
    Try
    Georgefix on Ebay. Don't know about the single but he sells good kits -fast and reasonable.
    '81 1100 MNS - "Midnight XSpress"
    Original except:
    Big John
    • tinman905
      • Aug 2007
      • 946
      • Orangeville,Ontario ,Canada
      Mikes XS too!!!
      BDF Special
        Chances are good if you go to a local shop or stealership service department you can drum one up.
          Oops, bummer...
          It wasn't the idle pilot jet I trashed, but the AIR pilot jet (the one that screws in at the air cleaner side). These aren't so common it seems, and to make matters worse the '78 is it's own size (210). The '79s used a 180, and as near as I can tell the newer carbs didn't even have these (at least they don't show on the parts fiche). Found the idle pilot and main jets all over, but not these.
          So, anybody have a dead '78 carb they can rob one off of....?
          '78E original owner
            Steve,
            In the 81 model carbs at least, they do have the removable pilot air jet in the inlet bell of the carb. They are in the lower left side of the bell and screw out. In the 81 model they are 185s. I went to my local yamarobbers and they ordered them for me at $3-4 each.
            All of the carbs should need that pilot air jet, the one item that changes in the inlet bell is the air vent shows up for a fourth hole in the later model carbs.
              Cool, if the local stealer had these at all, they should be able to get mine...
              Thanks!
              '78e original owner
              • foreda
                • 949
                • Southwest Louisiana
                Air jet
                Thanks!
                '78e original owner
                I probably have one in my stash. You need a 180 or 210 ?
                78 XS1100E Standard
                Coca Cola Red
                Hooker Headers
                1979 XS1100 Special
                1980 XS Standard
                2006 Roadstar Warrior
                • psycoreefer
                  • Feb 2008
                  • 1557
                  • Minden, NV
                  I believe the air jet is the same as the "small round" type mikuni main jet. Call around, a lot of shops stock these jets in small numbers. Just ask if they've got a small round type mikuni main jet size 180, then make sure it matches when you get there. Should run you around 4 bucks if prices are the same as when I got mine.
                  1979 xs1100 Special -
                  My Bike:
                  [link is broken]
                    A 210 if you've got one to spare... that would be great!
                    Send me a PM....
                    '78E original owner
                    • Ivan
                      • Jul 2008
                      • 2524
                      • Hutchinson KS
                      Ok, so I just repeated what someone else said, now back to your normally scheduled programming.
                      Ich habe dich nicht gefragt.
                      • tinman905
                        • Aug 2007
                        • 946
                        What powder are you using for the finish?
                        BDF Special
                          Eastwood 'reflective chrome'... the same stuff I reviewed. I'll try and post some pics when I get them done. I've been pretty happy with the Eastwood powders so far.
                          '78E original owner
