Carb Float height
  • fabricgator
    • Feb 2010
    • 67
    • Treasure Coast, Florida
    It appears that in the first four pictures, that the inlet side of your carbs as they set in your jig, are lower then the manifold side. That being said, I wonder if they are leveled laterally also. If your going to do the experiment, there should be some controlled constants.
    Of course, in situation they are sitting in all different attitudes especially while yanking and banking through some sweet twisties....
    Someone stated that you can't use a combination of plastic and brass floats...
    I disagree in that it is the effective regulation of the fuel level. The float measurement and setting will be different for plastic or brass, but if you check and adjust like this, they should be effectively calibrated.
    Kurt
    I have a parking problem everywhere I go....
    2001 Mitsubishi Montero
    1987 944 n/a
    1979 Titan
    1979 Yamaha XS 1100 SF
    1984 Suzuki SP 250
    1987 Santana 23
    1944 Aeronca L-3B Grasshopper
    If it fly's, float's or fornicates..... your better off having a lease!
