This being my very first post, hello to all.
It doesn't matter if the tire is off the ground or has weight on it. The pressure in the tire doesn't change unless you change the volume of the space the air must fill which is impossible when it comes to tires. A tire off the ground will just take the air faster when you fill it than one with weight on it but 38psi is 38psi. I just recently proved this point to an "engineer" at the job. I filled a set of truck tires to 130psi while off the ground then dropped the pressure and refilled the same tires while loaded. They still touched. So much for engineering degrees.
Just kidding. Maybe you should welcome the FNG now.
