XS11 and XJ1100 valves
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    I found a supplier that lists valves for Japanese bike by specs. Anybody know the specs for XS11 and XJ1100 valves? None of my books have this info.
    Geezer
  • 81xsproject
    • 3185
    • Fortuna, CA
    Tony, do they have any options like SS valves? Or are you just trying to find another bike that uses the same valves?
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • dpotter58
      • Aug 2004
      • 1846
      • Southern Maryland
      for an sf
      this is from my supplementary manual
      intake
      head diameter 36 +/- 0.2 mm
      face width 2.26 +/- 0.57 mm
      seat width 1.1 +/- 0.1mm
      margin thickness (min) 1.2 +/- 0.2 mm
      stem diameter 7 -0.0010 mm
      -0.0025
      exhaust
      head diameter 31 +0.2 mm
      margin thickness (min) 1.2 +/- 02mm
      1980 LG
      1981 LH
      • Geezer
        • May 2003
        • 2985
        Do you know what year these specs are for?
        Geezer
        intake
        -0.0025
        exhaust
        • 81xsproject
          • 3185
          • Fortuna, CA
          Since he owns 2 '81's and mentions that it is from the 'supplementary' manual, it is probably for the late model/80/larger valve heads. Which, of course, would be the most important valves to source
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
            • 7693
            He stated that it's for the SF, a 1979 Engine.
            The specs for the '81 are as follows:
            Intake:
            38mm head diameter
            2.26 -+0.57mm face width
            1.1-+0.1mm seat width
            0.7mm minimum margin
            7mm -0.010 to -0.025mm stem O.D.
            Exhaust:
            32mm head dia.
            2.26 -+0.57 face
            1.1-+0.1mm seat
            0.7mm min. margin
            7mm -0.025 to -0.040mm stem O.D.
            This is from LIT-11616-XS-13 The "H" manual with the previous manuals included.
            • Geezer
              • May 2003
              • 2985
              OK, if I can get stem length, I can see if we can get them. I would be nice if I could get the specs on the earlier engine's valves without pulling the head off one of my engines...
              Geezer
              • psycoreefer
                • Feb 2008
                • 1557
                • Minden, NV
                for an sf
                it's in the "title"
                so now you have both early and late....
                1979 xs1100 Special -
                My Bike:
                [link is broken]
                • Geezer
                  • May 2003
                  • 2985
                  Once I have the lengths, I'll see what I can do...
                  Those 38mm intakes are going to be tough but the later valves are available from CRC anyway.
                  Geezer
                  • tinman905
                    • Aug 2007
                    • 946
                    • Orangeville,Ontario ,Canada
                    If it helps I believe the FJ1100/1200 use the same valves .
                    BDF Special
                    • Geezer
                      • May 2003
                      • 2985
                      The FJ's have 4 valves per cylinder. If FJ head would transplant onto an XS11, I'd already be working on it... The XS11 and XJ1100 only being 2 valve per cylinder bikes is one of my pet peeves. Yamaha had the technology to do it but decided not to...
                      Geezer
                      • Yahman
                        • Mar 2008
                        • 779
                        • Salem, OR
                        Geezer
                        I can check the lengths of some from a 79. I'll post them later on today. I have to dig them out first.
                        Any other measurements that you want me to take?
                        Larry
                        82 XJ1100
                        80 XS1100G (Project bike)
                        64 Yamaha YA-6
                        77 Suzuki TS-185
                          I remember Dan Hodges posted a pic of a 4-valve head that was designed and would work on our bikes. He listed who sold it, but unsure of a price since I remember him saying something about "If money wasn't an option".
                          That being said, the valves on our bikes can move more air/fuel than even the biggest bore possible would need. Up to 1500cc if I remember right.
                          • Yahman
                            • Mar 2008
                            • 779
                            • Salem, OR
                            The 4 valve design keeps the velocities of the air/fuel mixture in a higher range, which keeps the mixture suspended in the air flow. It also helps throttle response.
                            Larry
                            82 XJ1100
                            64 Yamaha YA-6
                            77 Suzuki TS-185
                            • Geezer
                              • May 2003
                              • 2985
                              Larry
                              Nope, just length. I now have the other specs.
                              Geezer
