Dumb o-ring question
  • randy
    • Dec 2003
    • 4521
    So I went ahead and ordered the o-rings that are not included in the 'complete' gasket set (oil pump, main oilway, special nozzle) and I have a really simple stupid question that I'm sure you guys who have re-done a few motors will have the answer to. In the shop manual there is a caution to NOT use any sealer on this main oilway o-ring:
    My dumb question is: since this ring is so damned important, why would one NOT want any sealer there? BTW, I did find sealer on the original.
    Not an expert, but I would think it is due to the fact any sealer you apply that is XSive would go into the oil pump and or galleys and become a potential block of oil to bearings and such. JAT
    • tarzan
      • 1700
      • Chandler,Az.
      An o-ring should seal itself anyway.Sealer is overkill.IMHO
      80 SG XS1100
      14 Victory Cross Country
      • fabricgator
        • Feb 2010
        • 67
        • Treasure Coast, Florida
        Note*
        There are various compositions to orings as well as hardness... be sure to order you orings for the specific environment. Oil, fuel, (glycol coolant) movement or vibration... fuel with ethanol....
        Interactive O-Ring material selection chart, fliter by performance attribute to compare and select the right o-ring material
        Just a thought.
        Kurt
        I have a parking problem everywhere I go....
        2001 Mitsubishi Montero
        1987 944 n/a
        1979 Titan
        1979 Yamaha XS 1100 SF
        1984 Suzuki SP 250
        1987 Santana 23
        1944 Aeronca L-3B Grasshopper
        If it fly's, float's or fornicates..... your better off having a lease!
        • Yahman
          • Mar 2008
          • 779
          • Salem, OR
          Originally posted by randy
          o-rings that are not included in the 'complete' gasket set (oil pump, main oilway, special nozzle).
          I have been working on putting together some sets of all the o-rings that are hard to find for these bikes, I will add these to the list. If anyone knows of any others let me know and I'll add them to the list.
          Larry
          82 XJ1100
          80 XS1100G (Project bike)
          64 Yamaha YA-6
          77 Suzuki TS-185
          • randy
            • Dec 2003
            • 4521
            Ok, mĂ inshaft bearing cover takes 2 big funky ones...and the starter nose tends to leak....
            • petejw
              • 2269
              • sydney australia
              hey randy,
              id just put a smear of oil around
              the o ring.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
