Why the Tipover Switch won't trip while moving
    • 2074
    The switch does work and is a good design.Years ago i took the bike out on a winters day and there was a lot of salt/sand on the roads.I had to stop rather quickly and slid on loose salt/sand and the bike fell over and shut off.The switch did its intended job which i was thankful for!
      There's only one thing I can think of that having the switch would case a problem with. I have heard of a method of standing a bike back up after a fall by turning the handlebars hard and "driving" the bike into an upward position. I remember reading about that being part of the training for a moto cop. Unfortunately, the switch won't allow us to start the bike while laying down like that...
      Maybe we could wire in a switch to disable the TOS for that purpose!
      • cywelchjr
        XS-XJ Super Guru(Deceased)
        • 4450
        • Sacramento, CA
        Naw, you can do it manually. Just turn the front wheel towards the ground, grab the near handgrip and the grab rail while squatting facing away from the bike, and press your butt against the seat while starting to stand. The bike will stand right up. I've had to do it twice now, once in my driveway and once again on the first test drive of my replacement engine in a gravel parking lot (the true test of the technique in my mind). The entire technique is I believe outlined in the tech tips on the board here.
          That's because they don't have to buy their own parts when they gouge/grind up the sidecovers before it pops up.
          • Ivan
            • Jul 2008
            • 2524
            • Hutchinson KS
            To stand my XS back up, I use the index and middle finger on my right hand under the grab rail and just pull it up? The bike only weighs about #600, what's the big deal?
            Ich habe dich nicht gefragt.
            • cywelchjr
              • 4450
              • Sacramento, CA
              Well, the sarcasm is refreshing.
              If you look here you will find the tech tip on how to do this. I have exchanged messages with some small women who have used this technique on relatively heavy bikes with success.
              The first drop I tried the normal grunt method and with no success remembered about this technique and used it. It does make the task FAR easier.
              • Ivan
                • Jul 2008
                • 2524
                • Hutchinson KS
                Sarcasm?
                Ok, I use all four fingers. Seriously its not that tough, just pick the thing up?
                • cywelchjr
                  • 4450
                  • Sacramento, CA
                  Sarcasm?
                  Really, try the recommended method, it really is a LOT easier to pick it up using that method. Especially with a full dresser like mine. A naked bike may be a lot easier, but one of these things as a dresser can be a feat to pick up off the ground. And smaller guys can have some real trouble with them (as can the gals). Why strain yourself more than needed? Now I wouldn't suggest laying it down just to practice, just keep it in mind for the next time it's needed.
                    I haven't tried any fancy tricks yet, but the few times I have had the bike fall over, I have determined that I am "almost" completely unable to pick up the bike by myself. I spent 20 minutes in my office patio (where I park when it might rain) trying to lift it once. Of course, fuel spilled on the concrete, and melted the soles of my shoes (rubber is still smeared on the patio) making it even more difficult. That incident left me with sore wrists and thighs for 2 days! Maybe I'm just weak, but 200 lbs is my dead weight limit on a GOOD day. I don't know what the actual weight of a fallen bike is (anybody have a really big fish scale?), but it seems higher than 200 lbs.
                    I have the full-dresser thing too, but I have noticed that this may actually be a help, as it ends up resting on the saddlebag, preventing the bike from going all the way to the ground. The added weight of the empty luggage really isn't all THAT much (maybe 10 lbs. total).
                    I am seriously considering a practice run in my front yard with the tech tip's method. The only thing I did not do before was lock the wheel to the side. I dunno... Maybe this can be done as a training session at the MOTM rally!
                      ??? OK.. we'll all take turns knocking your bike over in the driveway and practice picking it up.
                      I'm with Ivan though. I just grab the handlebar that's down and the side of the grab rail and pick it up. Even better yet.. I stand there talking on the phone after mine falls over in the hotel parking lot, and I watch as Russ picks it up for me! lol.
                      • Ivan
                        • Jul 2008
                        • 2524
                        • Hutchinson KS
                        Just so happens I have a lot of practice, since my side stand doesn't extend automatically when I forget.
                        Instead of C-Bugs bike, can we go to a biker bar and practice on Harleys? I hear those guys are always willing to help with stuff like that.
                        • Bigfoot
                          XS-XJ GURU
                          • Sep 2005
                          • 1422
                          • Kansas City, Missouri
                          I always had enough of that "quick, get it up before someone sees you" adrenaline going the I just picked it up. Full dress XJ.
                          Harry
                          '79 Standard
                          '82 XJ1100
                          '84 FJ1100
                          Acta Non Verba
                          • XSokieSPECIAL
                            • Jun 2009
                            • 1631
                            • Tulsa, OK
                            I pulled over to get a cigarette out of my sissy bar bag one time and lost my balace when I turned around in the seat. (that was when I still smoked)
                            The bike (My old CX 500) ended up laying on the edge of the highway on the edge of the barrow pit top end about a foot below the bottom end.
                            The first two tries failed miserably, the third was a "I'm going to get this f^cking thing up if it kills me!" effort.
                            Thank god for Walmart, I needed new underwear.
                              • 8893
                              Worst one that happened to me was dropping the bike when paying the toll on the Mass. Pike in Worcester. Try picking up a bike when you're feet are slipping in oil. It did shut off tho.
