yamalube carb cleaner
  • SFSPECBIKER79
    • Jul 2008
    • 403
    • NC
    my question is this. will this stuff eat up throttle butterfly seals mixed 2 parts water to 1 part yamalube carb cleaner? i found that it works well onthe carbs, but did not cover the butter fly shafts with it i like the smell of it better than the spray types. just curious about how it reacts with rubber seals.
    79 xs 1100 spec & 80 xs 1100 g
  • CatatonicBug
    • 6117
    • Clinton, UT
    I have read somewhere around here that this is the one actual "carb cleaner" that will not eat the shaft seals. At least they will be fresh smelling!
    • yamtom
      • 275
      • Midland Michigan
      yamalube carb cleaner safer?
      I concur with CBug, Ive read that in just the last day or so, but cant remember exactly where the thread is.
      Bikes Now.
      80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
      79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
      83 Yammi Venture with custom footboards, 20k miles.
      83 Yammi Venture parts bike
      99 Valkyrie shield and bags 37k miles like new
      08 ZX 14 Kawa Ninja 6k miles Sold
      • Yahman
        • Mar 2008
        • 779
        • Salem, OR
        No problem
        They will not be harmed, that has been my experience.
        Larry
        82 XJ1100
        80 XS1100G (Project bike)
        64 Yamaha YA-6
        77 Suzuki TS-185
        • yamahaman
          • Jun 2007
          • 9
          • New Braunfels,Texas
          yamaha carb cleaner
          I'm a factory trained Yamaha tech.No it will not harm the seals.I've used it filling the carbs on the bike and disassembled off the bike.It is the best I've ever seen.It may turn your brass seats,mains,and pilots pink.You'll still have to verify the passages are clear with spray cleaner.
          • kta
            • May 2006
            • 32
            • Los Angeles, CA
            After using any cleaner I generally flush the carbs with water, then hose them down with wd-40. The WD arguably isn't the greatest choice, but as long as you get fuel flowing in short order it'll keep the slides nice and smooth without evaporating/drying in your jets.
            ..... I'll just skip to the Baja part.
            Follow my Evan Fell Cycles: Motorcycle Blog
            evanfell.com | twitter.com/evanfell_cycles | flavors.me/evanfell
            lots of my motorcycle photos | personal favorites slideshow
            • LuckyEddie
              • 166
              • Middleville, Michigan
              Yamaha Carb Cleaner
              Greetings,
              Great stuff! I have used it in the past. But beware, the formulation has changed. I have not tried the new stuff yet. check this link: http://www.randakks.com/TechTip1.htm
              LuckyEddie
              1980 XS1100LG Midnight special
              1982 XV750J Virago
              1976 GL1000
              1978 GL1000 Supercharged
              1981 XV920RH (chain drive)
              • yamtom
                • 275
                • Midland Michigan
                carb cleaner
                HI,
                There is an indication that the cleaner has changed formulation, on the above rankaaks link, it appears that there may be two types of cleaner available, one that mixes with gas, and one that mixes with water. Yamahaman, can you elucidate on this please. Thanks
                Bikes Now.
