Pilot Jets
  • fabricgator
    • Feb 2010
    • 67
    • Treasure Coast, Florida
    Pilot Jets
    Hello and thank you for imparting your vast and extensive knowledge upon me.
    Could someone tell me how to inject PB Blaster to the backside of the pilot jet threads.
    I have been looking at the casting, and I am asking if there is a combination of setup that would direct the PB Blaster to flow to the other side of the pilot jet threads. IE: reinstall the idle needle screw and inject blaster here....
    I see that the idle screw is not the route, just using that as an example.
    If you have been following, I finally removed the idle needle screw after a few days soaking and application of heat to the casting with my micro torch.
    I am fashioning a screw driver for the best fit this morning. Upon removal, I will be complete in my disassembly. I am convinced that this non removal of the pilot jets in the past has been the failure in my previous repair/rebuilding attempt.
    Have a great day.... it is beautiful weather here for a ride!
    Kurt
    I have a parking problem everywhere I go....
    2001 Mitsubishi Montero
    1987 944 n/a
    1979 Titan
    1979 Yamaha XS 1100 SF
    1984 Suzuki SP 250
    1987 Santana 23
    1944 Aeronca L-3B Grasshopper
    If it fly's, float's or fornicates..... your better off having a lease!
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    If you don't smoke then enlist the help of someone who does.
    Blow smoke through the jet or opening using a straw (drinking or swizzle stick type). See where the smoke exits and PB Blast from there.
    We were told this tip for finding passages in automatic transmission valve bodies
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • fabricgator
      • Feb 2010
      • 67
      Thanks Pat,
      I've just got two out and two remain..... I'm using a screw extractor on these....
      It is taking quite a bit of torque. The two removed were all cruded up, so this will be my shining moment in a finely tuned piece of Japanese artwork.
      I continue to soak, tap, heat, repeat.... they will submit!
      Can I get these from a local cycle shop?
      The jet port (?name?) at the inlet bell and the idle air screw ports are connected to the back of the pilot jet. So PB Blaster may be being applied if the pilot jet will allow passage (not clogged).
      Wish me luck!
      Kurt
      1987 944 n/a
      1979 Titan
      1984 Suzuki SP 250
      1987 Santana 23
      • fabricgator
        • Feb 2010
        • 67
        Originally posted by Pat Kelly
        "Do you want it done right? Or do you want me to do it?"
        This is great....... can't wait to use it at work....
        Kurt
        1987 944 n/a
        1979 Titan
        1984 Suzuki SP 250
        1987 Santana 23
        • dbeardslee
          • 4385
          • Maineville, OH
          If you put the nozzle in the air jet, it should hit the back of the pilot jet. Maybe this will help - it's for BS32's but they're pretty much the same as the 34's. Fuel Flow Diagrams
          • fabricgator
            • Feb 2010
            • 67
            Thanks Doug...
            Air Jet.... thats what they call it.
            Kurt
            1987 944 n/a
            1979 Titan
            1984 Suzuki SP 250
            1987 Santana 23
            • dbeardslee
              • 4385
              • Maineville, OH
              You can get the pilots at Mikes XS for $6 a pair - BS30/96 type. Shouldn't take too long for you to get them as Mikes is also in Florida, about 50 miles north of Tampa.
                • 1376
                Cheap Jets?
                Jets can be found fairly cheap:
                Trained pilots are a little more expensive.
                • fabricgator
                  • Feb 2010
                  • 67
                  Does anyone know what tap I would use to chase the pilot jet threads?
                  I had / have been using a screw extractor for a few days with no luck.
                  I line drilled it with a #40 bit and got a good grab. After soaking, heating, failing, repeat.... I thought that possibly it was bound down by the nose of the pilot jet.
                  I line drilled it with a #30 bit, well within the threads and was able to go back in with the small extractor and remove the nose of the jet through the #30 hole through the threaded portion. Now I have the threaded section of the pilot jet in the hole.
                  I customized a screw extractor to go back it for the next portion and failed. when I shook out the debris, I noted that I had silver shards and not the brass...oopsie
                  If I can get the remains of the brass threads out, I will need to chase what is left of the threads (fingers crossed).... Additionally, if I know what the spec drill size is, I can line bore it to the tapping size, that should get me darn close to just having a brass spring in the threads.
                  In hind site, which is usually 20/20, I should have tried this experiment on the carb with the broken float post..... I was not hoisting Heineken and doing maintenance. That is probably where I began to mess up.
                  Kurt
                  1987 944 n/a
                  1979 Titan
                  1984 Suzuki SP 250
                  1987 Santana 23
                  • XSokieSPECIAL
                    • Jun 2009
                    • 1631
                    • Tulsa, OK
                    Beer is the lubrication you need to get anything done.
                    Which carbs did you intercourse up? I have 1 2 & 4.
                    • fabricgator
                      • Feb 2010
                      • 67
                      Thanks Greg,
                      Carb #2 has a broken float post from PO and still has a pilot jet installed in it. If I get the pilot jet out, it should be still serviceable with the broken post and a jury rig. Of course I'd prefer to have is right...
                      Carb #3 may have a pilot jet tread situation as previously mentioned.
                      Too much blood in my alcohol stream...
                      Kurt
                      1987 944 n/a
                      1979 Titan
                      1984 Suzuki SP 250
                      1987 Santana 23
                      • XSokieSPECIAL
                        • Jun 2009
                        • 1631
                        • Tulsa, OK
                        Have another drink dammit.......
                        # 2 is good, # 3 has a broken post because of my drunk ass trying to knock the pin out.
                        Sorry.
                        He he pickled bastard.
                          • 8795
                          I'm almost sure it's a M5-.80, BTW, a small Allen wrench can be hammered into the pilot jet to aid in it's removal. Sometimes it works, sometimes it doesn't.
                          07 Triumph Tiger 1050
                          • MindWebs
                            • May 2009
                            • 431
                            • Baldwin, WI
                            fire, fire is cool...
                            aluminum expands more then brass.
                            remove all parts that can burn,
                            then take propane torch and heat carb body in the area of stuck brass.
                            then when it's good and hot, spray WD40 into area of brass.
                            this is not for the faint of heart. LOTS of smoke and most likely flames.
                            after flames die down. repeat this procedure 2-3 times.
                            and you will find that the offending brass should screw right out.
                            I use this method on any carb i am dismantling for the first time.
                            Good Luck!!
                            • fabricgator
                              • Feb 2010
                              • 67
                              Thanks for the advice guys,
                              I had been using a small torch and heating the area to the point where I could not hold the diaphram horn continuously, I thought that may have been hot enough, but then possibly not.
                              And Phil, the hex key idea is great... I think there is even a fluted screw extractor set that works in a 1/8th hole, so either of those may get me back on the road.
                              Another thought is that I may have the right heat temp but I should heat for a longer period of time. My concern was the butterfly shaft seals. Ah, whats another vacuum leak, the holders look rough....
                              Welp, I'm going to the garage to melt some aluminum... *hic*
                              Spanx Gize.....
                              Kurt
                              1987 944 n/a
                              1979 Titan
                              1984 Suzuki SP 250
                              1987 Santana 23
