Stupid Special handlebar question
  • skippy344
    • Feb 2003
    • 449
    • College Station, Texas
    So, I have always felt "squished" on the Scorpion. Then, I restore SWMBO's 1982 XJ650 Maxim, and I feel really comfortable. WTF?
    I get to looking at both the steeds, side by side, and I notice that her handle bars are wider, at the grip tip, than mine! WTF?
    So, I took a measurement, and I am 28" from hole to hole at the end of the grips. She is 31.5" from hole to hole.
    Can someone, who has a Special, measure their width from the center of the holes?
    I think I may have smaller bars on Scorpion than stock.
    Thanks,
    Gone but never Forgotten:
    1980 XS11SG - "Scorpion"
    Current:
    2006 Yamaha FJR1300A - "Orion"
    2007 Honda CBR600RR - "Twitch"
    "Life is not a journey to the grave, with the intention of arriving safely in a pretty and well preserved body; but rather to skid on broadside, thoroughly used up, totally worn out and loudly proclaiming:
    WOW - What a ride!
  • Rev.Rick
    • Dec 2009
    • 129
    • Loganville Georgia
    Hey Skippy, I have two sets of the Special "garden tiller" bars. One set came off my xs1100 and they were only 25.5" center to center and the other set came off my xs850 they are 28.5" center to center
    Rev.Rick
    What I ride now: 1980 XS1100 Special
    What I used to Ride: 1980 XS850, 1984 Honda V65 Sabre, 1974 Honda CB750 ss, Yamaha YZ 480 (bored YZ400), Kawasaki 500 triple
    Amazing Grace, how sweet the sound that saved a wretch like me! John Newton (1725-1807)
    • skippy344
      • Feb 2003
      • 449
      WOW, that's quite a difference among all these bars, huh? I would have expected the dimensions to be relatively close, if not exact?
      I guess I'll have to go try out some after market bars and see if I can find something wider and more comfortable.
      Thanks, Rev,
      Current:
      WOW - What a ride!
      • Rev.Rick
        • Dec 2009
        • 129
        No problem Skippy, I actually despise the special bars. I replaced both of the stock bars on my specials with superbike bars. I like them much better. Their not as strait as drag bars and they provide much better riding posture (at least for me)
        Rev.Rick
        • skippy344
          • Feb 2003
          • 449
          Rev,
          How did you resolve the issue of the front master cylinder and its crazy angle on the original sloping buckhorn bar?
          If I change my bar configuration, like you did, I might consider changing out master cylinders with one, like from an '99 VMax.
          Whaddya think?
          Current:
          WOW - What a ride!
          • Rev.Rick
            • Dec 2009
            • 129
            Skippy, I used a stock MC from the xs11 standard model, It sits very level when placed on the superbike bars. Just a word to the wise. If you go this route make sure that you get a MC with a 11/16 bore and not a 14mm bore. the xs650 with a single front disk used the smaller bore MC, the 11/16 bore is made to work with the duel front disk application.
            Rev.Rick
            • skippy344
              • Feb 2003
              • 449
              Roger that! The VMax has dual front discs, so it might work OK, and is readily available.
              I'll report back when I resolve this.
              Thanks,
              Current:
              WOW - What a ride!
                Originally posted by skippy344
                Rev,
                Whaddya think?
                Hi Skippy,
                I don't let it bother me. The only time the m/c has to be level is when you take the top off and on those rare occasions you can swivel the m/c on the bars and turn the bars to full lock to bring the m/c to near 'nuff level.
                If you are sufficiently bothered by how the stocker looks on flatter bars to swap it the ONLY thing that's important in swapping to a different m/c is to make sure it's the same piston diameter.
                • Ivan
                  • Jul 2008
                  • 2524
                  • Hutchinson KS
                  So, Rev. Rick, If a guy were to put a wider tank on the XS, from a Maxim, do you think the 850 bars would give enough spread as to not get into the tank when the head is turned?
                  Ich habe dich nicht gefragt.
                    Originally posted by Rev.Rick
                    Skippy, I used a stock MC from the xs11 standard model, It sits very level when placed on the superbike bars. Just a word to the wise. If you go this route make sure that you get a MC with a 11/16 bore and not a 14mm bore. the xs650 with a single front disk used the smaller bore MC, the 11/16 bore is made to work with the dual front disk application.
                    Hi Rick,
                    FWIW, the post '77 XS650 m/c works just great when you add the left-side disk & caliper.
                    That m/c is way too big to operate only one caliper which accounts for it's wooden feel in a single disk application.
                    See this chart:-
                    for more about m/c to caliper ratios than you really need to know.
                    • TDodge7
                      • May 2009
                      • 246
                      i've always been pretty fond of the european bars , the angle on the m/c is fine . here is a set on mine .
                      • XSokieSPECIAL
                        • Jun 2009
                        • 1631
                        • Tulsa, OK
                        You need a new speedo Dodge. 85 doesn't even cover 3rd gear.
                        Not to change the subject ya know.
                        • jmnjrpa
                          • Jun 2009
                          • 863
                          • Lewisville, Texas
                          Hey Ivan,
                          On that tank contact question. I have already looked into it as I'm in the process of expanding a tank. The stop lugs that keep it from smacking the tank will have to be modified. I am considering drill, tap and a set screw in the lug to restrict movement. I don't think it will adjust the turn radius to radically.
                          '81 1100 MNS - "Midnight XSpress"
                          Original except:
                          Big John
                          • jmnjrpa
                            • Jun 2009
                            • 863
                            • Lewisville, Texas
                            Btw
                            I am referring to my 1100 but the same should apply to all.
                            Original except:
                            Big John
