ugh forks from ebay
  • freak_leg
    • Aug 2009
    • 152
    • Lakeville, Minnesota
    ugh forks from ebay
    Ok so here is the deal guys I bought a rebuild set of forks from ebay. while putting the axle in i ran across a problem...
    at some point some on broke the stud off the left fork. they drilled and tapped it. kinda. so when i was tightening the bolt i experienced the all to familiar feeling of tight tight loose!! Son of a.... it stripped out, not the bold that would be easy to replace, oh no the hole in the fork.
    Anyhow does anyone have some experience here?? could i just re-tap it with a bigger bolt? I fear this would just strip out again. Could i cut the head off a bolt and weld it into the hole??
    Help PLEASE!!
    Happy / Safe ridding everyone
    Tony
    Tony
    78 xs11 aftermarket 4-2 HD mufflers, whats left of it is stock. A work in progress for sure.
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    You can use a helicoil to repair the threads and replace the bolt with the proper threaded stud.
    BDF Special
      Yep, the aluminum is softer than the bolt so it will strip out first.
      Helicoil kit or drill and tap next size up.
      • latexeses
        • Jun 2008
        • 1491
        • California
        There is the option of taking it to a welding shop and having the hole welded up, redrilled, tapped and.......$$$$$$$$
        Everything on hold...
        • tarzan
          • 1700
          • Chandler,Az.
          +2 on the heli-coil.
          You can get a little heli-coil kit at ace hardware.
          Well, at the one by my house anyway.Easy fix and just as strong as original.
          80 SG XS1100
          14 Victory Cross Country
            • 3193
            +3 on the heli-coil. It is a much stronger fix than drilling and tapping by far and does not cost a lot either.
              Originally posted by tinman905
              ...replace the bolt with the proper threaded stud.
              DO make sure you use a stud; even with a helicoil, running bolts into/out of aluminum isn't that great of an idea. I'd also give very serious thought to 'stacking' two inserts in there to increase thread strength, seeing how this helps hold on the front axle.
              Just my .02
              '78E original owner
              • jmnjrpa
                • Jun 2009
                • 863
                • Lewisville, Texas
                Forget the helicoil if
                You can get a Keensert it will be much better.
                '81 1100 MNS - "Midnight XSpress"
                Original except:
                Big John
                  If all else fails, you can take your old left lower fork leg and swap it out (assuming you have one) with the damaged unit. If you need an extra lower Standard left fork leg, I probably got one.
                    Just to add, if you use a 5/16 - 18 UNC tap, that works perfectly, it's just a bit larger than the stock metric stud. BTDT, HTH
                    • mxmikie
                      • Aug 2008
                      • 482
                      • Bouse az
                      i have a lower leg for a standard
                      • Pat Kelly
                        • 3046
                        • Golden Valley, AZ
                        Best advise I have is to give the bike to me and you won;t have to worry about it anymore
                        Pat Kelly
                        <p-lkelly@sbcglobal.net>
                        1978 XS1100E (The Force)
                        1980 XS1100LG (The Dark Side)
                        1999 Suburban (The Ship)
                        1994 Dodge Spirit (Son #1)
                        1968 F100 (Valentine)
                        • freak_leg
                          • Aug 2009
                          • 152
                          Thanks for the offer pat
                          I talked to a buddy of mine about it. His exact words "No problem give me the good fork and the old one and i'll just swap the studs. You'll never know it was broken." Thank god for good friends who also happen to be mechanics!!
                          Thanks guys!
                          Tony
                          • fabricgator
                            • Feb 2010
                            • 67
                            • Treasure Coast, Florida
                            I have a spare set of standard forks that I bought...
                            I thought I was going to be able to replace the tubes on my special, I think the tubes are shorter then my special. It has been a few years since I looked at them.
                            Kurt
                            I have a parking problem everywhere I go....
                            2001 Mitsubishi Montero
                            1987 944 n/a
                            1979 Titan
                            1979 Yamaha XS 1100 SF
                            1984 Suzuki SP 250
                            1987 Santana 23
                            1944 Aeronca L-3B Grasshopper
                            If it fly's, float's or fornicates..... your better off having a lease!
                              I guess I missed something here. You said you broke the stud? I stripped the threads off of the stud and replaced it. I would attempt to remove the remnant of the broken stud and replace it. It could be an easier process than you might think.
