First Motorcycle, Need Advice
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    #46
    Originally posted by Eastspur
    I think would be more inclined to buy a new cap than spend 15 bucks on a seal. That way I could have a key, new seal, and nice new chrome.
    Now see, I would go with the seal myself because then I still have the single key for the ignition, gas cap, helmet lock and the side cover lock (if I ever get the end piece fixed so it can lock on again.
    • fabricgator
      • Feb 2010
      • 67
      • Treasure Coast, Florida
      #47
      Hello,
      I've been following the progress of your recovery.
      I do a little amateur lock smithing. A possible scenario, and I need to do it to mine, is to bring your serviceable gas tank lock/cap to a technician and see if he can reset the tumblers to the new ignition key.
      Additionally, I read here that just about any Yamaha key will operate the left side cover cylinder, and I find that to not be true. I have to use the key for the gas cap to operate that cylinder. I do believe that the side cover cylinder only uses two or three tumblers in that cylinder. I guess I will look into that one someday soon too.
      I found and repaired my side cover by fishing the locking "chunk" from inside the side cover locking mechanism and did an epoxy and JB weld repair back onto the side cover. It worked well as it has held up for five years to date and even passed my stress test last week when I had forgot that I had repaired it.
      Good luck with your new ride!
      Kurt
      I have a parking problem everywhere I go....
      2001 Mitsubishi Montero
      1987 944 n/a
      1979 Titan
      1979 Yamaha XS 1100 SF
      1984 Suzuki SP 250
      1987 Santana 23
      1944 Aeronca L-3B Grasshopper
      If it fly's, float's or fornicates..... your better off having a lease!
