Turn Signal Balljoint?
  • dontlikeoc
    • Nov 2009
    • 173
    • Alhambra, CA
    I am very slowly working on restoring my XS1100 Special laid by the previous owner. The wierdest item I need - now I realized - is a balljoint of the rear turn signal base. I looked at the micro fiche but could not find the part. (Is that part of the frame, and there is no way to replace it?)
    Did anybody ever replace it, and/or happen to know the part number for it?
    dontlikeoc
    1981 XS1100 Special Edition
    Alhambra, CA
  • mxmikie
    • Aug 2008
    • 482
    • Bouse az
    a picture sure would help......................
    careful what you wish for.........you might get it
      • 8672
      This?
      • dontlikeoc
        • Nov 2009
        • 173
        • Alhambra, CA
        I apologize for no pictures. Phil, this looks like it. Thank you so much.
        The only thing is that, in the pictures at the link, they look very elastic that cannot stay bent. That socket in the frame that holds the "flasher" itself may be bent...I looked again hoping that is was part of a grab bar...It looks solidly part of the frame - nothing I can replace...
        dontlikeoc
        Alhambra, CA
          • 8672
          There are a couple metal tabs that hold that rubber bushing in place which could be straightened if necessary. The rubber can also tear causing the signal stem to wobble. If the signal stem is removed from the bike, you should be able to see what the problem is.
          • dontlikeoc
            • Nov 2009
            • 173
            • Alhambra, CA
            Phil, thanks again for your comments.
            It is certainly the metal tab(s) - to me it looks like one piece of squashy metal in the socket - that are(is) in the round socket hole that are mushed.
            What is the correct method of taking the old one out and putting in a new one? It doesnt look like they are threaded. Do I have to hammer them out/in?
            dontlikeoc
            Alhambra, CA
              • 8672
              Take off the 14mm nut inside the frame on the end of the stalk. It's hard to access and probably a bit rusted, so spray it down with penetrating oil first. Disconnect the hot wire and pull the stalk out. Just pop the rubber piece out. When this happened to me, I didn't have access to a new rubber piece, so I used 2 large washers, one on each side of the frame mount, no more wobbley. The rubber is there to prevent snapping the stalk off in case of a mishap.
              • 79XS11F
                • Jul 2006
                • 3563
                • Ottawa, Ont. Canada
                Also make sure your using that large cupped steel washers between the rubber grommet and the nut that goes on the threaded tube from the signal stem. Bottom of the cupped shape of the washer goes toward the signal stem Don't forget to attach the ground wires between the nut and the washer when your putting it together.
                Rob
                KEEP THE RUBBER SIDE DOWN
                1978 XS1100E Modified
                1978 XS500E
                1979 XS1100F Restored
                1981 Suzuki GS1100
                1983 Suzuki GS750S Katana
                1983 Honda CB900 Custom
                • dontlikeoc
                  • Nov 2009
                  • 173
                  • Alhambra, CA
                  Phil and 79XS11F,
                  Thank you for the detailed advice. Now I know what I expect. I will work on this through the week.
                  dontlikeoc
                  Alhambra, CA
