A Call To All Great Exhaust Builders
    • 8766
    Originally posted by Mashermoto
    I will say though that even with all 12 discs in place it is much quiter than I thought it would be...which is what I wanted. It has just enough of a mellow growl to please me, but it doesn't make my head rattle going down the road.
    However, if you want loud, you can take all the discs off and run it open
    Less discs= quieter, richer mixture, more back pressure
    More discs= louder, leaner mixture, less back pressure
    One time I was running 10 discs in mine (single 4-1 Supertrapp) and all was good for the type of roads in my area. When I reached the twisty roads in NC, I found that I needed more low end grunt. I ran 5 discs increasing back pressure, which gave the bike better low end. You'll find out later that adding and removing discs will change your plug color. Supertrapp, A+ for tunability.
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      #77
      How about a 2nd/3rd gear drive by?
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
      • xj11john
        • Jun 2005
        • 440
        • Lafayette, TN
        #78
        Very nice exhaust, and I like what you've done with the bike too!
        '82 Xj1100j
        "Ride for the Son"
        John
          • 6762
          #79
          I found a MAC 4 to 1 on ebay recently and also bought the SuperTrapp Muffler....soon to do this...I'll document it in my own thread...but this thread was most certainly an inspiration!
          persona non grata
          • R.S.
            • Apr 2010
            • 24
            #80
            Hate to ask the obvious, but why not just clone the OEM pipes - perhaps with a supertrap fitting?
            Just take the exact dimensions, and make them?
            • cptomlinson
              • 12
              • Baton Rouge, LA
              #81
              Holes in Baffles
              the bike on this youtube video sounds great! http://www.youtube.com/watch?v=zB2s4mGZsng. he says that he drilled holes in the baffles. would that cause the exhaust temp to go up and damage the engine? anyone know? if it does not hurt anything, how and where would you drill these holes?
              Christopher P. Tomlinson
              • jrotilie
                • Dec 2016
                • 4
                • Kent, OH.
                #82
                Hello, I am a tig welder in Ohio, also looking for custom exhaust, about to make my own 4-2 that has both mufflers on the same side similar to harley, if it turns out ok I may consider selling custom setups, but custom work is not cheap.
                80 xs1100sg
                  • 3918
                  Sounds interesting.
                  • jrotilie
                    • Dec 2016
                    • 4
                    • Kent, OH.
                    #84
                    Sounds interesting.
                    I haven't seen it done on a xs so far, so just gonna wing it, the question is: pie cuts or bend my own tube
                    80 xs1100sg
                      #85
                      Hey there Jrotilie,
                      The diameter for the headers are ~1.5", and unless you have a fancy Mandrell bending machine, then it can be a real PITA to manually bend the pipes without stuffing them with sand or such to keep them from collapsing, wrinkling, etc.!
                      I made a set of headers for a fellow Xsive a couple of years ago, take a look at this thread for hopefully some ideas!?
                      • Bax
                        • 344
                        • Merrimack, NH
                        #86
                        Still making custom SS exhaust
                        Just throwing it out there.....
                        Last year I got a replacement exhaust from Heinz Wyes for my SG. Still made per order with long lead time, ordered late Jan 16 and received Sep 16. Excellent materials and craftsmanship. Drop in pipes just have to drill the holes in the support fins.
                          • 3918
                          Is that the German stainless system?
                          • Bax
                            • 344
                            • Merrimack, NH
                            #88
                            Yup. The custom exhaust from Germany.
                            The contact info is in the link.
