A Call To All Great Exhaust Builders
  • T99Ford
    • 678
    • Bozeman,MT
    I would tend to agree with Cy. Remember that while engineers have performance in mind, it is not extreme performance. And, they are considering emissions, manufacturing and assembly costs, longevity, and rideability. I think it is for these reasons that the aftermarket offers the gains that it does. This is even more prevalent today, if one looks at modern sport bikes. The R6, for example, is reputed to show the largest aftermarket exhaust gains, and has the most restricted stock exhaust on the market. The aftermarket products improve performance tenfold over stock, not because the engineers can't design it, but because they are hamstrung by other (non-performance related) influences. Stock is rarely the best performer, but probably rather the best "all around" performer for those who don't know better. So just because the engineers designed it one way does not make it the best. It just makes it compliant with the engineer's requirements.
    There have been major advances in exhaust technology in the 30 years post XS production, and I would venture that if modern engineering of exhaust were to be applied to an aftermarket exhaust for one of these bikes, one would see larger gains than any of the period aftermarket exhausts.
    This is not denying that the Yamaha engineers knew what they were doing, but rather stating that the goals of the Yamaha engineer was not to optimize every aspect of performance. Mass production and having to make a bike anyone could ride limited the performance characteristics of their bike.
    But this is great! Those like me who want to mod and then fool with specific characteristics of a modded bike can, and those who would rather jaunt around the countryside and not worry about their bike can do that as well!
    Healthy is merely the slowest rate at which you can die
    Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. Thompson
    • daveyg
      • Feb 2009
      • 411
      • Boise, ID
      I understand that it makes sense that a 1,4;2,3 exhaust "should" work better, but many aftermarket exhausts even use the 1,2;3,4 method, I have on my shelf a titanium header for a GSX-R 1000, not a very cheap hunk of metal, yet it also uses the 1,2;3,4 Tri-Y design. I'm just saying that the costs vs benefits appear to lead toward the simpler design. One of the costs with our beloved 11 being ground clearance, another being oil filter access. Both of which would be extremely difficult to attain with a 1,4;2,3 system.
      BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
      80 XS1100SG(cafe in progress *slowly)
      • T99Ford
        • 678
        • Bozeman,MT
        Ground clearance is a huge issue on these bikes for a 4-2-1. The stance of the bike does not allow for mounting like on a sport bike. There would need to be some engineering work there for sure.
        • daveyg
          • Feb 2009
          • 411
          • Boise, ID
          #34
          And in my opinion there are some very large flaws with the current model of R6, namely on exhaust, that could be easily fixed with "off highway use" parts. The greatest of all being the catalytic converter/pre muffler that sits under the bike, where the only muffler seen from outside is the tiny 6" long piece that acts merely as a glasspack. A 1,2;3,4 tri-Y design would obviously be more effective, but the US government doesnt care about hp...
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            #35
            Actually my Jardine system provides almost 0 interference with the oil filter or the oil pan for that matter. For that matter, as I understand it, they also achieved the same length on the pipes to the collectors for each cylinder which is also hard to achieve. I have to say I also love the sound of it, with it being a bit aggressive without being overly loud. I can still blip the throttle and set off car alarms with it though.
            • Pat Kelly
              • 3046
              • Golden Valley, AZ
              #36
              My Jardine 'spagetti' pipes are quieter than the stock pipes. Ground clearance is fine but lean angle is less as the system is wider than stock.
              My RC Eng 4 into 1 is tunable for loudness and back-pressure. Lean angle is no issue but ground clearance is (bottom 2 pipes are now 'D' shaped). This system was designed for track use, not real-world. I have mulled the idea of making a 'Y' pipe from the collector to run 2 (tuneable SuperTrapp) mufflers for astetic reasons. The bike just looks naked on the left side with no muffler.
              Both systems retain the centerstand and don't require removal for acessing the oil filter.
              Pat Kelly
              <p-lkelly@sbcglobal.net>
              1978 XS1100E (The Force)
              1980 XS1100LG (The Dark Side)
              1999 Suburban (The Ship)
              1994 Dodge Spirit (Son #1)
              1968 F100 (Valentine)
              • Mashermoto
                • Nov 2006
                • 230
                • Yukon, OK
                #37
                Pat, I agree that the XS1100 looks naked on the left side with out a muffler. With a 4-2-1 system or 4-1 system, I don't understand why every manufacturer's systems exit to the right I guess when they designed their systems, they checked the file to see what they did for the last bike built and it was to exit to the right
                I called MAC yesterday and they actually returned my call They are not going to start production on their 4-2 taper tip system for 6 more weeks They are also not open to any of our suggestions for a new exhaust design. Because they are the only US supplier of exhaust systems for our bikes, any new design has to be home grown.
                IMHO, I think the reasonable solution is a 4-2 system with shorty reverse cone mufflers that extend out half way between the rear axle and rear foot pegs. It would look good, sound good, should perform reasonably well, provide easy access to the oil filter, allow oil coolers, and might allow center stand retention
                Now then...who is going to build it
                My heros have always been flat trackers.
                • Pat Kelly
                  • 3046
                  • Golden Valley, AZ
                  #38
                  Possible reason for right-side exit is for flat-trackers. If it only comes out one side have one part number for everyone.
                  Pat Kelly
                    • 8962
                    Another theory. The right side exhaust exit doesn't interefere with the side stand.
                    • Mathh
                      • Nov 2006
                      • 699
                      • Beek, Netherlands
                      #40
                      I think it has something to do with the mess the chaindrive on normal bikes makes. I know there were some left side models in those days,merely used by side car owners..
                      MV Agusta Brutale 910R '06.
                      Yamaha MT-09 Tracer '15 grey.
                        #41
                        Perhaps it started with circle track racing and the need for left side ground clearnace but none on the right?
                        • Mashermoto
                          • Nov 2006
                          • 230
                          • Yukon, OK
                          #42
                          Well...with MAC now out of the picture...this is my next attempt to get a system on this bike
                          There was only one on Ebay from the seller who actually lowered his buy it now price for me So I'm going to use this as a test case...if it works out I'll buy another one for the other side.
                          I'm going to attempt to use these old MAC 4-2 header with the SuperTrapp 443-2217 universal mufflers.
                          I've got this problem with one side...the gasket flange is broke I'm not real sure how I'm going to work that out.
                          It's going to be a close fit for the out side can to clear the foot peg mounting bracket. The muffler shown is 3 inch diameter and the SuperTrapp is 3.5 inches before it tapers up to 4 inch. However, it looks like the 17 inch length will extend the exhaust end right between the rear axle and foot peg just like I wanted
                          One down side is that I will need to make the headers flat black where as I wanted an all chrome system. But I might actually like the black headers mounted with the brushed stainless steel mufflers more than I think
                          Chroming the headers is cost prohibitive and probably wouldn't go well with the SS mufflers
                          • T99Ford
                            • 678
                            • Bozeman,MT
                            #43
                            Masher,
                            Good luck with that plan! Will be watching to see how that can looks, as I have thought about getting rid of this Mac one. I hope it works for you this time. I have black headers on mine, to no detriment to the looks. I do have to touch them up from rock ships from time to time:
                            BTW, is your rear fender mounted all the way, or are you working with it? It just looks a little "flat", like it could stick out a little more. But it might just be the angle of the photo, too. I was just comparing it against mine, which is still mounted stock:
                            Nice looking bike! I like your use of colors a lot!
                              #44
                              Here's a post from a few years back - Denny Zander's home-built exhaust system:
                              • Mashermoto
                                • Nov 2006
                                • 230
                                • Yukon, OK
                                #45
                                T71,
                                I've seen your bike before and I gotta say that looking over yours again makes me warm up to the black header option even more I think I will be happy with it
                                Also, the fender pictured is in the OEM mounting position. That's just the way a 78 Standard mounts
                                Ken,
                                I tried something like Denny's setup.
                                I bought a couple of Kawasaki ZX10R mufflers on Ebay and attempted to mount them on each side using the MAC 4-2 header shown in the above pictures.
                                I ran into some of the same problems with the rear pegs as Denny experienced. The location is great for rear passenger comfort, but makes anything but a below mount muffler difficult to pull off. At least without major modifications. Sport bikes get away with it because the rear pegs are mounted so much higher. So I moved the mufflers way back and tilted them upwards. Even so, once I got a pipe built to bridge the header to the muffler, the exhaust pipe would still be in the way of someone with an average to large foot.
                                I abandoned the project after taking an honest look at the design and felt like I just couldn't live with it. The pipe that bridged the header to the muffler just looked way out of place. It looked like I was trying too hard to make it work. The other problem is that there were some tough angles to cut to make the pipe fit up. Even with the aid of a chop saw, I was wasting expensive mandrel bend pipe. Things got worse when I went to welding the pieces together
                                I've floated this balloon a few times now and will shamelessly do it again...somebody needs to step up and build a decent system for our bikes and put it out here for the XS1100 community. The fat cat companies are not up to the task
