Does this screw put gas into the throat right there where it comes in or does cause suction to pull gas thru the pilot jet....i guess what i'm wondering....do i need gas resistant o-rings on the air fuel adj. Screw........
Air fuel adj. Screw
Air fuel adj. Screw
DENNIS
1981 MNS..1980 CARBS , STOCK AIR BOX, FIVE 1/2" HOLES IN BACK OF MUFFLERS (SINCE COVERED UP WITH A BIG WASHER)
1983 HONDA 350R
1972 YAMAHA 250 MX
196? MONTESA 250 ENDURO STRIPPED DOWN
1967 BENEILI 125 ENDURO (NOWHERE NEAR BIG ENOUGH)Tags: None
Yes, they need to be able to be in gasoline.Life is what happens while your planning everything else!
And where is this "air jet-main" thats supposed to be size 140?..........xs 1100 lh....bs34-iiiDENNIS
1983 HONDA 350R
1972 YAMAHA 250 MX
The main air jet is a pressed in jet in the inlet bell of the carb. The pilot air jet is the lower left hole looking at the inlet bell, it is a threaded removable jet (Mikuni small round jet).
Now the main FUEL jet is a Mikuni LARGE round jet and is threaded into the bottom of the needle jet/emulsion tube and accessed inside the float bowl. But 140 would be a large jet for that on a version iii carb that would be stock for an LH.Life is what happens while your planning everything else!
If you want to know how the internals work on these carbs, you might take a look at this. It's for BS32's, but it's relevant for the BS34's.I think I have a loose screw behind the handlebars.
