carb choke/butterfly leaking
  • BigDick
    • 521
    • McConnell AFB, KS
    So back before I knew better I dipped the entire carb bodies while cleaning them. Needless to say, now I have a nice gas stain coming from at least my #4 carb body. My question is what type of rebuild kit do i need? I know the normal kits only have new needles and bowl gaskets. Will my local Yama-robbers have what I need? Thanks all.
    1980 XS11SG
    Dunlop elite 3's, progressive fork springs, tkat brace
    Stock motor, airbox, carbs, exhaust
    ratted out, mean, and nasty
    • 3193
    I ordered a set of throttle shaft seals and butterfly screws from mikesxs. They appear to be the right ones, but I have not installed them as yet. Maybe some others have had experience with them that can enlighten you more.
    • Ivan
      • Jul 2008
      • 2524
      • Hutchinson KS
      Hit Cycle Station on Douglas and Seneca(?). It looks like an old gas station that is now painted in black and white checkers. Kinda a ratty looking place, but they probably have a box of old carb parts you can dig through to see if you can find a few seals.
      Ich habe dich nicht gefragt.
      • MrFreeze5
        • Aug 2009
        • 138
        • Denver, CO
        If you soaked the entire carb assembly, not only are the seals fried, but your diaphragms are probably bloated and deformed as well. They will need to be replaced more than likely. Buying new diaphragms is ridiculously expensive(~$600) though. Its probably cheaper to find a new set of carbs.
        1981 XS11SH Custom Project - Juggernaut
        1990 FZR600 Hybrid Streetfighter - Lilith
        1996 FZR600 Custom Project
        1994 FZR600
        • BigDick
          • 521
          • McConnell AFB, KS
          I know the place you're talking about. I'm planning on holding off until my taxes go through in any event.
          I'm pretty sure that i pulled the diaphragms out when I dipped them. There's half a chance that the seals just plain wore out. I dipped the bodies in one ounce(maybe one cup) of acetone mixed with one gallon of gas. Next time we get a few days of nice weather like we just had I'll pull the carbs and check them over real close.
          1980 XS11SG
