Warning, Defective
    • 8893
    Warning, Defective
    In case any of you are using the MikesXS fuel filters, P/N 20-0013, the two I put on about a week ago both started leaking. Can't really tell where they were leaking from, but after checking with vacuum, they don't hold. My theory is that Mike is trying to burn up all our 11's.
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    I tried those on a XS650 and had the same exact result.
    Rick
    650SF
    XS1100SG Project bike
    • tinman905
      • Aug 2007
      • 946
      • Orangeville,Ontario ,Canada
      Thanks for the heads up I have a set I was going to install soon !!!!!!!!!!!!!
      BDF Special
      • tarzan
        • 1700
        • Chandler,Az.
        I have a set I bought last summer.I haven't installed yet either.
        Has anyone contacted mikesxs?
        80 SG XS1100
        14 Victory Cross Country
          • 3193
          I tried those and the one leaked from brand new. The second one made it about 50 miles then it leaked. It was not worth contacting Mikes about for the couple of bucks they cost, but I am not getting any more. Thought maybe it was just mine that were not good.
          • GARTHXS
            • 1631
            • Seattle
            ditto
            Mine lasted about 1 yr
            91 kwaka kz1000p
            Stock
            ( Insert clever quote here )
            • Guy_b_g
              • May 2007
              • 790
              • Beverly Hills, Florida
              I had a couple, put one on my riding lawnmower, it lasted about 30 min then dumped fuel all over. Looked just like those pictured when I took it off. I was d**m lucky it didn't go up in flames. I thought I just had it too close to the head, guess not...
              Guy
              '78E
              • cowboybob998
                • Mar 2009
                • 371
                • KC MO
                It might be worth contacting mikes xs, because it sounds like this could be real problem if a bike was to catch fire because of this filter, thanks for the warning
                1979 xs1100 f
                142 main, 45 pilot, Jardeen crosover 4/2, no air box
                floats @ 25.7
                1979 xs1100 F
                1978 gl 1000 goldwing
                1981 gl 1100 goldwing
                !986 venture royale 1300
                Just an ol long haired country boy, come to town to spend some egg money
                when ya get bucked off, get back on
                • Crazcnuk
                  • 2980
                  • Hinton, AB, Canada
                  I also put a couple of those on, with the same result. Mine leaked at the hose connections. As you can see from the photos, these filters can't take heat, and they deform very quickly.
                  I put hose clips on them and they have been holding.Try and put them in a spot where the hose is straight (if you can find one!)
                  '05 ST1300
                    I installed a pair of them a few years ago, far enough away from the engine so that heat didn't play a factor. Then one started to leak, and it had been rubbing against one of the bolt heads on a hose clamp, so thought that was the cause/reason for the leak, not any manufacturing defect!?
                    However, with the number of folks posting about them acting defectively, I would think/hope that MikesXS would like to know about a product problem, no matter what kind of bike it was on!
                      • 8061
                      Parts evaluation
                      This may be helpful.
                        • 8893
                        Funny thing is that I ran these exact MikesXS filters for 2 years with no problems, but these new ones failed.
                        • ManitoulinLad
                          • 358
                          • Manitoulin Island,Ont.,Canada this is in Lake Huron
                          I have one as spare & its hittin the garbage can tonight - man this place is so helpfull -Dan
                          '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
                          1179 big bore kit, 80SG motor
                          Rebuilt head, valves
                          TC Bros Forward Controls (Brass Pegs)
                          Tkat Fork Brace
                          T.C. Spade Fuse Box
                          Dyna Coils & wires
                          Mikesxs shocks,controls,& bars (special)
                          ISO grips with stelleto ends
                          4 into 1 black Bassani exhaust
                          Bridgestone Spitfires
                          Tuned by Tinman905
                          & a will to keep it.
                          • latexeses
                            • Jun 2008
                            • 1491
                            • California
                            That's what crapped on a moped I had years ago when I ran some "gasohol". Could they be giving up because of the gas? Not that it matters but I am wondering if someone dumped a bunch of old stock on Mike??
                            Everything on hold...
                            • Rev.Rick
                              • Dec 2009
                              • 129
                              • Loganville Georgia
                              I have used those cheap in line filters found on lawn mowers and have never had an issue. I do alot of small engine repair so I always have some around. Thanks for the warning about those from Mikesxs. I will avoid them. They remind me of those glass inline filters with the replacable cartridge used on 3/8 and 1/2" fuel line. I had a 1971 Firebird with a 400 big block I built. I like the way those glass ones looked but I always had problems with them leaking (could have been the fact I had a Holley blue pump feeding a hog holley 850 double pump y'all reckon).
                              Rev.Rick
                              What I ride now: 1980 XS1100 Special
                              What I used to Ride: 1980 XS850, 1984 Honda V65 Sabre, 1974 Honda CB750 ss, Yamaha YZ 480 (bored YZ400), Kawasaki 500 triple
                              Amazing Grace, how sweet the sound that saved a wretch like me! John Newton (1725-1807)
