Ignitor unit asy 1 378-001
  • ErickTheBold57
    • Jan 2010
    • 1
    Hello, Thanks for looking
    I have a XJ 1100 J Maxim. It appears from the sop that I need to get a new IGNITOR UNIT ASY part number 378-001 as I don't have any spark. the problem is that I can not buy one from any where that I have found. Any Ideas? The shop said that they did not have the manual's tester. but all that I could test shows that it is the issuel
    Please help. Erick
    I am at erickpiponius@yahoo,com
  • Lamric
    XStremely XSive(Deceased)
    • 410
    • Kenley, Surrey, England
    Whoo there. I don't have the answer but I think you should back up a bit and tell us some more about the problem and what symptoms you have. What have you tested, what were the results, and what is still working ?
    Brian
      I still don't have a clue what he wants or where that part number comes from. That doesn't match a TCI or the coil numbers... so not sure what he's after.
      • tw1980
        • Apr 2009
        • 662
        • Bend OR
        I don't have any idea what you're looking for Erick.That's not a good part #.You can look up Yamaha part #'s on Yamahas website or at Bike Bandit.Welcome aboard.
        Terry
        1980 special (Phyllis)
        1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
