Clutch cable question
  • thewright1
    • Aug 2009
    • 198
    • Orange County CA
    Hey Guys,
    I just got a new clutch cable and put it on the bike. The first one I bought was a little too long, so I bought another one which I thought was a little too short, but after doing some messing around, I got it working, but now i'm not sure if I have it set up right. For example, when I put it in first gear, press the clutch and try to back up, it's kind of hard to back up (It still backs up, just takes a little bit of work), I don't know if that has something to do with the bike being shaft driven but as soon as I release the clutch, I can't move anywhere (so that parts working right at least). I haven't actually had the bike long enough to know if that's normal or not. Does that sound right to you?
    As far as the adjustments I made, I did some messing around with the pieces in the image below:
    1980 XS1100SG
    In the process of making her look pretty!
    P.S., TomRodgers has the best avatar icon ever!
  • petejw
    • 2269
    • sydney australia
    If your trying to push the bike backwards without it running
    in gear and the clutch pulled in it will be a bit harder to move,
    the 'thingy' above needs to be adjusted properly, lock nut loosened
    have the screw nipped up to where its lightly seated, then backed out a quarter
    of a turn, then tighten the lock nut. Adjust the cable at the handle bars so theres some
    slack in the cable. Start the bike and put it in gear and see how the clutch
    operates. Hope this helps.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      Put the trany in natural and see if it's the same amount of resistance to move it around as it is with the bike in gear and the clutch level pulled. If it's the same things are likely OK. If it's less work in natural then the clutch might need adjustment. If so, confirm the adjustment under that cover first followed by adjustment at the level.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
