Freeze and Release
    • 3193
    Freeze and Release
    I tried this product on my carbs to get a broken idle/air needle out. I sprayed it on the area, and waited a few minutes. When I turned the carbs over the broken needle fell out. Maybe I was just lucky or maybe it is a good product, who knows but I will be trying it if there is a next time.
    • 2104
    I wonder how well that would work on exhaust studs, seems like I just read about someone bustin' one off the other day. Would You have a spare head to experiment with? If I can get that down here I have an old vw head I can try it on.
      F'shizzle!!!
      Might work for warts, skin flaps, or even prepping for that second naval piercing.
      Thank you Loctite!!
        • 3193
        I dont know if it would get larger parts cold enough to do much but like I say it worked well on the needle to aluminum combination of the carbs. Apparently it cracks the bond with the difference in temps and that allows the lubricant to seep in. I am no chemist but hey it worked for me.
        • XSrunner
          • Feb 2008
          • 97
          • Batemans Bay AUSTRALIA
          hi guy's i use this stuff on very bolt that i haven't undone before works great except for the cam tensioner bolt that broke off in the head ( previous thread) but it was very badly rusted a mechanic friend help me get it out with left handed drill bits. i put never seize grease on all the bolts i replace..
          JOHN'O
          Xs1100E 1978
          American Import Cruiser
