how to tell battery polarity?
  • dontlikeoc
    • Nov 2009
    • 173
    • Alhambra, CA
    I have a feeling that the POs have changed a lot of wirings to customize. I have a feeling that he(they) may have used a red wire for negative instead of black.
    1) Is there a way to tell which battery cable is for positive/negative?
    2) To be frank, I connected the battery thinking the red is for positive. But nothing happened. Is it possible that I fried something electrical - like relays? The fuse box is fresh and the battery is new and full.
    dontlikeoc
    1981 XS1100 Special Edition
    Alhambra, CA
  • randy
    • Dec 2003
    • 4521
    The positive battery post should be connected to the lead that goes directly to the starter solenoid. The negative should be connected to the frame.
    • CatatonicBug
      • 6117
      • Clinton, UT
      If it makes any difference, the negative (neutral) is on the left side of the bike, and the positive is on the right. When the battery is installed, the terminals should be on the rearward edge of the battery. The battery itself should be labeled with + and - to indicate polarity as well.
      Never trust wire color to indicate polarity. You never know who did the wiring before you, and not everyone thinks about how the next guy is going to have to deal with whatever they just "fixed". As a test, you can set up a small fan (like the kind from a computer case) with loose leads on it. If you touch it to the wiring, and the fan pushes air like it is designed, polarity is correct. If it goes in reverse, polarity is backward.
      • Ivan
        • Jul 2008
        • 2524
        • Hutchinson KS
        if you don't know on the battery, because of no markings, about the only way to tell is a LED. IIRC the long wire goes to positive, and it will only light in one direction.
        Ich habe dich nicht gefragt.
          • 8753
          A digital volt meter will tell you by displaying a (-) symbol if it's hooked up backwards to the battery.
          • randy
            • Dec 2003
            • 4521
            Methinks he's got other issues, like keyswitch or fuses. Even if the battery were hooked up backwards, idiot lights would light and starter would spin, although backwards. The TCI might not be happy and possibly the other 'black boxes' either, but SOMETHING should be happening.
            • dontlikeoc
              • Nov 2009
              • 173
              • Alhambra, CA
              Thanks for all the suggestions.
              The black cable certainly goes to the starter...It really looks like the PO used the wrong colors for wrong polarities. I will get a multimeter to be very sure. The $3 multimeter doesnt seems to be working...
              dontlikeoc
              Alhambra, CA
              • Spider
                • Aug 2009
                • 92
                • Upstate, NY
                As if the electrical on these bikes weren't unstable enough, now our batteries are bipolar....
                1978 XS1100
                "Of all the adversaries I have faced, I was the worst."
                • randy
                  • Dec 2003
                  • 4521
                  Color doesn't mean a damn thing....
                    • 7712
                    Get a new 9V. battery for the $3 meter! they put in a CHEAP battery, and they usually last about 2 hours of on time.
                      I had a "Buddy" try to help me jump start my bike once, and he hooked up the jumper cables backwards on the car side. I thought it may have fried something because it didn't do anything after that, but it just blew the main 30 amp fuse. Mine is under the seat, but it's an XJ, so I can't tell you where yours is... but that would be one of my first checks.
                      As for testing the battery... get a test light. They're probably about as costly as your $3 meter. Clamp one end to your battery post, then touch a ground. No light? Attach it to the other battery post and try again. If it lights, that's the positive side.
                      • Dragon Tamer
                        XStremely XSive(Deceased)
                        • Sep 2006
                        • 426
                        Randy,
                        "The starter may turn backwards"? Most starters that I have worked with are shunt wound and don't really care about polarity. Are these different??
                        The Old Tamer
                        _________________________
