Manual Petcocks
    The aluminum solder sounds like the way to go. I've tried the JB Weld only, it does work, but it will slowly deteriorate, say over a year. Can't remember if I used the 5 minute crap, or the good kind.
    • randy
      • Dec 2003
      • 4521
      Then there's this stuff, haven't tried it, but maybe it would work for a float post repair?
      • oseaghdha
        • 1075
        • N43.02.5,W88.14.2
        Originally posted by oseaghdha
        I also suspect you can just swap Special levers into a STD housing and get the same effect (without the solder), but I have not verified this theory yet.
        No bueno on this. I finally got them both on the bench today and the levers are different diameters.
        If I had a CNC, I'd carve some up with the single slot.
        As far as the diaphragm goes, I just replaced it with a gasket I cut out of stock.
        XS1100SF
        XS1100F
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          #34
          Can I put petcocks from a 79 SF onto the 79 F tank? Are the center to center distances for the bolts the same?
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            #35
            No, the petcocks from standard and special tanks do not interchange. The sizes are different.
